Hi guys! My name is Joey and I am from Canada. I have a BCNR33 and have just done a few modifications to my car and it has running issue....
Specification:
RB26 stock head stock cam
Tomei 2.8 stroker kit bottom end
Injector Dynamic 1000cc + injector resistor pack deleted
Ebay twin entry fuel rail + stainless braided hoses
Tomei intank fuel pump + Type L regulator
Apexi' power FC + datalogit
Stock AFM
Stock turbo
Autobahn88 intercooler
Stock recir BOV
The engine was rebuilt about 500km ago and have good compression, if not perfect. Timing should be perfect as I never touch it
I have replumbed the fuel line myself and it gets very good and stable fuel pressure
So right now I am using a default setting on my FC and I set the injector to 44.4% and +.228ms. The car has difficulty starting and eventually it can idle at about 400~450 rpm and my wideband shows about 12.8 during it's idling. When I step on the throttle it stalls. So right now I don't know what to do.....I would hate to remove all the work I did and revert back to the stock ECU and stock injector.....
I would like to know what I should start checking or what could be wrong? Can it be my spark plug gap? but then it can sort of run.....
Really really really appreciate anyone input into my sitaution! Thanks again!!!
Fuel plumbing bcnr33 by Komachi1, on Flickr
Edited by Komachi
https://www.sau.com.au/forums/topic/424195-rb26-id1000-power-fc-setting/
Thank you!!!!! One more question...if I want to set my base pressure at 4 bar...for whatever reason it is, I use the flow rate and battery voltage deadtime data at 4 bar in the chart and my car should run the same?
yeah, ooh and dont forget ID's love high base pressures.... its not uncommon to have 70-90psi base pressures even on NA cars.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
