Hey guys,
Just filled up the tank then as i was walking back to the car i noticed fuel dripping..
Got home and jumped under the car again and saw it was still going.
When i filled up the tank the pump clicked as it does when it's full, but i saw i had 20L left til full tank (just did the sending unit fix so that's not the problem) so i thought i'd throw the nozzle in again just for 2 seconds then it clicked again. Could that of been why it's dripping from here? I haven't hit anything that could cause a leak.
Help..?
Edit: Video didn't upload, how do you get videos to play on here?
Edit #2: Video attached
View My Video
http://tinypic.com/player.php?v=291eqhg&s=5
Edited by Seano350GT
https://www.sau.com.au/forums/topic/424268-fuel-leak/
My bet is that when you did your "sending unit" fix, You didn't correctly reassemble the unit. The large o ring around the top is hard to seat once removed.
Go to Nissan and buy a new one, and take it appart, and re seat the o ring.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830159
that's what i'm thinking Alex. I did the whole sending unit fix myself but the only bit i did not do was reconnect the main hose to the tank - my friend did it while i was over the other side of the car but i asked him to make sure it's on properly.. i haven't noticed fuel leaking in the last 2 weeks though.
Just checked it again, still dripping really slowly though. Going to pull the seat up and check everything.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830209
The main hose is pretty idiot proof, but the o ring has caught people out before.
It swells in contact with fuel, making it hard to seat properly. Well worth buy g a new one from Nissan. Ask for a 350z fuel tank o ring, the large one, and you'll get the right thing.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830225
ok so i pulled the seats forward and lifted off the cover. Seems like the main hose to the tank was not fully connected, it had about a cm of movement until i was fully connected. There was also a small pool or fuel around that area too which i cleaned up. Turned the car on and jumped under it and noticed the dripping came to almost a complete stop. Turned it off and packed up all my crap then looked again and it was still dripping a tiny bit. Will look at it in half an hour, also that O ring you speak of was not touched when i did the sending unit clean so it won't be the issue unless it's somehow gone faulty.
My mate that did it isn't the brightest tool in the shed only reason i got him to do it was because he's smaller than me and it's so f*cking uncomfortable to get into the back of our car lol..
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830247
Ummm, you have been in the tank, which means you have disturbed the o ring.
The outlet hose should click on so the clip clicks. When you put the whole hanger unit back in, you need to get he o ring seated right. Just use some brake cleaner to wash the fuel off and see where it's coming out.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830290
I don't see what is to "lol" about here.
It seems that neither of you are the sharpest tools in the shed. No offence but messing with critical systems such as fuel and brakes without at least doing the homework beforehand is not only dangerous to yourself but to others as well.
General rule of thumb is when you've disturbed seals in such systems, NEVER REUSE THEM!
And personally, if I don't consider someone to be all that intelligent, the last thing I would do is allow that person to work on it.
So, get a new o-ring from your dealership, grab a copy of the workshop manual and do some homework. Otherwise, pay a mechanic to help you avoid catching fire.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830455
Do you happen to have a part # or something to make it easier at Nissan?
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830663
So i got up this morning and checked the car, no fuel leaking underneath at all. Started it and got to work, checked it again and it's leaking same as it was yesterday. I will grab an O-ring from Nissan today. I am getting the boys in the workshop here to look at it today, they are qualified techs..
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6830665
This guy, yup, he knows.
https://www.sau.com.au/forums/topic/424268-fuel-leak/#findComment-6831135
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
