I can assure you, from experience (at QR yesterday), plummetting down the straight and feeling your brakes not gripping the rotors is not a fun feeling.
Nah the brakes worked but the pedal was sinking to the floor when hot. couple of cool down laps & they were sweet again.
  • Like 1
Exactly the same problem I had... Looked it up and it's caused by the fluid boiling. 3 remedies are: Titanium shims behind the pads, Better brake fluid, braided lines.
Oh and to make matters worse, once it's boiled once, it's more likely to boil again :(
Motul RBF 600...get it. I have never had brake fade on QR and I go HARD on all the straights every lap, no cooldowns for my baby :P
I also have braided lines, but they don't help with cooling just give a better pedal feel as they don't expand under pressure.
Apparently braided makes a bigger difference when the fluid is hot :) Have you tried the motul rbf660? Any idea if it's compatible with my car?
Well heat makes rubber more pliable so it would expand more when the fluid is hot. The 600 and 660 are about the same, except the 660 boils about 20 deg. higher and costs about twice as much. Just use 600, more than enough as your pads will give out before you boil fluid (assuming they are just street pads).
Hmmmm I can get 660 at a *reasonable* price... I don't wanna change it twice if I upgrade other components later... Argh... I dunno, I might be over-thinking this...
I can't make this and I needed to cause of work, so can you guys do me a favour please. Can you ask what settings to run for 50% street 50% track.
Castor
Front camber
Rear camber
Rear toe
What ever else that can be adjusted please on an alignment place. Thanks.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
