So I was under the car fitting front swaybar bushes over the weekend and I took the undertray off to get to them and got 2 small shocks - oil and coolant!
I knew about the oil actually, as Id seen the telltale drops under my car space. Whats the deal with that leak anyway? I used a new washer and did it up tight enough when I last changed the oil, why does it still leak? How can I avoid this next oil change?
More importantly though, is the coolant leak. It seemed fresh enough and while I couldnt see where exactly it was leaking from it had covered what I believe is the power steering pump in a bit of coolant. I checked and my coolant res level and its near the min, so keeping an eye on it. FYI that pic i took is under the turbo side of the engine with the the sump to one corner. Also I replaced 6 water hoses 2 years ago, plus the radiator ones, so this has me a little confused. Thoughts of what part of the engine this leak might originate or why?
Thanks
Edited by ausdrift
https://www.sau.com.au/forums/topic/424370-2-leaks-oil-and-coolant/
Thats weird if its AC fluid, just because the colour is really that of coolant, but it is nowhere near any coolant lines I know of, so certainly a possibility. I thoughts AC was a gassed system though?
The washer used is simply one from bunnings that was the same size as the one that came with the A/M magnet plug I bought. maybe Ill just get it from the car parts shop next time
The correct washers are not the flat type, they're a crush washer. See what your local Nissan dealer wants for one or buy a 10 pack from ebay...
http://www.ebay.com.au/itm/160648840409?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
When the A/C system is recharged, an ultra violet die is added to help find leaks. The dye is fluorescent yellow/green and when gas weeps out it takes the oil/dye with it giving the desired affect. It can often look like a coolant stain/leak.
Edited by White GTS-T
Good to know, about washers, will have to investigate proper ones next time.
And with the dye weaping from the AC compressor, what exactly might be the reason for the leak and/or what would need to be replaced/fixed? Anyone had this and know what it might cost? Dang, I just paid for an AC regas before summer too...
Thanks for the info too White GTS-T
It looks as though it's leaking from the compressor housing, where the compressor 'head' bolts to the housing. It may just be leaking from the suction/discharge fitting o-rings on top of the compressor and leaking down. But more than likely it's the internal housing o-ring. Best bet is to take it to a Fridgy to confirm.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
