Keep an eye in the events section as there will be cruises coming up. If you don't mind a drive I'll start looking at a mid may Newcastle cruise soon! It's been a while since we did the last one :)
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835092
Welcome to SAU.NSW Adrian and Benny.
By all means, your private meetups are fine...
...but keep checking the "Events" section for whatever the Club puts on.
26th May = AGM - nah you wouldn't want to go to that. Actually, you would!!!!!
3rd June = Texi - lots skids > lots of fun
5th July = Tech Night - about servicing, blue slips, engineering certificates
+ Cruise that might be appearing real soon. :)
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835093
Easiest way is probably PM Shell on the forum as I can't remember where the forms are lol....
Please keep in mind it will take a little time as the guys/girls have full time jobs and do the SAU stuff in their spare time...
SAU NSW runs some great events and is full of info you will likely need for your beast...
Look forward to catching up at an event!
If you like skids, be at Texi as Terry mentioned, it's even good as a spectator :yes:
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835111
Yeah its such a good group has already helped me out alot cheers an thanks guys for being so friendly :) hope to catch up soon
SAU in general is a pretty friendly and relaxed... A few basic rules such as searching subjects before starting new threads etc apply in terms of making your stay easier, alternatively send one of us a PM as i am sure there are some questions we can help with, if not we can point you in the right direction at least :D
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835168
I see we have a leak of information :)
Confirm me in for that one!
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835360
Thanks Kat! I had a brain malfunction this morning :P
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835483
I'am in for the Tech Night as well. (Membership has been paid for, waiting for response)
..and if I still have my '33, Im in for this cruise. Whereabouts are you located mate?
We are the Newcastle crew but there is a large amount on the Central Coast and inbetween too! The cruises are generally spread into different locations! The Events section should have any planned cruises listed normally but we have all been a bit flat out lately.... In general we were trying to do one a month which worked for a while but we will get it back there again soon :yes:
Once again, Tech nights will be in the events section and are definately a good thing! :D
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835490
Remember to also take the 24th of August off work and clear any plans!!
SAU Wakefield track day!!
Thanks Man! Forgot about that one..... Email to boss going right MEOW!!!
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6835567
Isn't Texi 10/06?
:D Wakefield....sweet
Edited by RiseofBrutality
https://www.sau.com.au/forums/topic/424502-nissan-meet-up/#findComment-6837720
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
