The restrictor is not going into this motor.
This GTR is getting rebuilt stock.
Just so she runs and looks good.
The restrictor is part of the "I'm going to build a power house when I am not poor anymore." engine project.
lol
But if I do build a solid engine it's going to comprise of this:
NISMO oil pump.
TOMEI metal gasket kit.
33 crank.
ARP main studs and head studs.
ACL big end kit.
Tomei sump baffle.
Poncam Series 2.
Adjustable cam gears
Full HKS turbo kit + manifold etc.
Basically a standard 450 whp build.
I wont build it though.
I can fix stuff, but I can't do all the gapping, etc that specialised engine builders can.
Scared of busting my hard earned cash. Rather let croydon racing do the hard work. lol
Very true.
But is it worth running the GTR on the street for normal driving with the restrictor and extended sump?
Do I need an upgraded pump if I do put the restrictor in?
Will it screw up the engine if it is not a built motor?
I can't afford a new motor upfront, and already had half the stuff anyway.
It's going to be stock as.
What do you suggest I do to add on it?
Not looking for power, just want a nice reliable driver.
No hard launches etc on the stock motor.
I WILL build a monster eventually, RB30 block, etc.
I was thinking Genuine parts rebuild like I am doing.
But should I put the restrictor in with the stock pump and stock sump?
So - today I started really getting into it, got the aircon out, etc.
So anyway.
I was told there was a little oil in the radiator fluid, but there wasn't too much.
HAHAHA.
LOLNO.
There was a LITTLE BIT of WATER in the OIL in the RADIATOR.
Still draining.
Slimy brown sludge. Yeeeaaaaw!
BHG for sure.
I figure seeing as I have no job I'll pull the hard yeards and see it through during the nights due to looking for jobs and calling around during the day.
So here we go...
Front bar off, the number plate bracket bolt was rusted in, drilled it out re-tapped it, and got back to the hard stuff.
Stock? Hmm..
Ah well, free adjustable cam gears. XD
No baffles, nothing. I am disappointed. :-(
No collision damage. :-D
WHAT IS THIS?
Uh, was attached to the horn loom.
Temp sensor of some kind?
Looks slimy.
Old and wrinkly.
lol.
So - now I'm sure it is a blown head gasket, or someone has filled the radiator with baby rear end stuff... >.>
Bought these ages ago after making them on the JDM site thingo.
I have three spares just in case. lol
Ordered these AGES ago too.
More insight into this GTR.
Took the aircon condenser out, slowly removing the lines, working my way to the pump.
Put the front member back in with horns etc.
WHAT IS THIS? I think it's a temp sensor? am I right?
So yeah, more things I can't afford to do.
If anyone knows anyone hiring in the north shore, short term, part time etc, looking for minimum of 500 a week.
Please guys, If I get a job I owe whoever gets me one a case of beer of their choice.
:worship:
I have my whitecard, I'm a tyre fitter, can easily adapt to any kind of manual work, did playground construction, and some wood bolster barbed wire fencing.
Short term or long term, just need a job now.
I haven't gotten around to getting my forklift licence yet, but I know how to drive one. lol
If you can help, big thanks ahead of it man. :-)
Back the the GTR.
It had THREE alarm systems in it.
lolwhut
All were hooked up too. haha.
Anyway, all of them are out, making a switch board where the ash tray was and moulding it in, RWD toggle switch, Electric fans toggle switch, Heater bar switch, Ignition switch (cuts the main line on the Start on the column so the switch needs to be on to start the car, which is hooked to a clutch mechanism so the clutch must be in to start also, seeing as I can't trust alarms since the last one failed, I know it all seems stupid to do this, but it'll make sense later down the track.) So yeah....
Four switches I want for no good reason basically. lol.
And I moved the lighter socket to the centre console to charge phones, etc.
I don't want cables everywhere...
:whistling:
OK, GOOD NEWS.
I got a job in the city.
Bad news - I'm fitting exotic tyres and run flats.
Good news - I get 25 bux an hour.
Bad news - I work four and a half days a week.
Good news - I get time to work on the GTR.
Bad news - still on about the same wage due to day pay as last job.
Got a job though.
Still kickin'.
:-D
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
