The restrictor is not going into this motor.
This GTR is getting rebuilt stock.
Just so she runs and looks good.
The restrictor is part of the "I'm going to build a power house when I am not poor anymore." engine project.
lol
But if I do build a solid engine it's going to comprise of this:
NISMO oil pump.
TOMEI metal gasket kit.
33 crank.
ARP main studs and head studs.
ACL big end kit.
Tomei sump baffle.
Poncam Series 2.
Adjustable cam gears
Full HKS turbo kit + manifold etc.
Basically a standard 450 whp build.
I wont build it though.
I can fix stuff, but I can't do all the gapping, etc that specialised engine builders can.
Scared of busting my hard earned cash. Rather let croydon racing do the hard work. lol
Very true.
But is it worth running the GTR on the street for normal driving with the restrictor and extended sump?
Do I need an upgraded pump if I do put the restrictor in?
Will it screw up the engine if it is not a built motor?
I can't afford a new motor upfront, and already had half the stuff anyway.
It's going to be stock as.
What do you suggest I do to add on it?
Not looking for power, just want a nice reliable driver.
No hard launches etc on the stock motor.
I WILL build a monster eventually, RB30 block, etc.
I was thinking Genuine parts rebuild like I am doing.
But should I put the restrictor in with the stock pump and stock sump?
So - today I started really getting into it, got the aircon out, etc.
So anyway.
I was told there was a little oil in the radiator fluid, but there wasn't too much.
HAHAHA.
LOLNO.
There was a LITTLE BIT of WATER in the OIL in the RADIATOR.
Still draining.
Slimy brown sludge. Yeeeaaaaw!
BHG for sure.
I figure seeing as I have no job I'll pull the hard yeards and see it through during the nights due to looking for jobs and calling around during the day.
So here we go...
Front bar off, the number plate bracket bolt was rusted in, drilled it out re-tapped it, and got back to the hard stuff.
Stock? Hmm..
Ah well, free adjustable cam gears. XD
No baffles, nothing. I am disappointed. :-(
No collision damage. :-D
WHAT IS THIS?
Uh, was attached to the horn loom.
Temp sensor of some kind?
Looks slimy.
Old and wrinkly.
lol.
So - now I'm sure it is a blown head gasket, or someone has filled the radiator with baby rear end stuff... >.>
Bought these ages ago after making them on the JDM site thingo.
I have three spares just in case. lol
Ordered these AGES ago too.
More insight into this GTR.
Took the aircon condenser out, slowly removing the lines, working my way to the pump.
Put the front member back in with horns etc.
WHAT IS THIS? I think it's a temp sensor? am I right?
So yeah, more things I can't afford to do.
If anyone knows anyone hiring in the north shore, short term, part time etc, looking for minimum of 500 a week.
Please guys, If I get a job I owe whoever gets me one a case of beer of their choice.
:worship:
I have my whitecard, I'm a tyre fitter, can easily adapt to any kind of manual work, did playground construction, and some wood bolster barbed wire fencing.
Short term or long term, just need a job now.
I haven't gotten around to getting my forklift licence yet, but I know how to drive one. lol
If you can help, big thanks ahead of it man. :-)
Back the the GTR.
It had THREE alarm systems in it.
lolwhut
All were hooked up too. haha.
Anyway, all of them are out, making a switch board where the ash tray was and moulding it in, RWD toggle switch, Electric fans toggle switch, Heater bar switch, Ignition switch (cuts the main line on the Start on the column so the switch needs to be on to start the car, which is hooked to a clutch mechanism so the clutch must be in to start also, seeing as I can't trust alarms since the last one failed, I know it all seems stupid to do this, but it'll make sense later down the track.) So yeah....
Four switches I want for no good reason basically. lol.
And I moved the lighter socket to the centre console to charge phones, etc.
I don't want cables everywhere...
:whistling:
OK, GOOD NEWS.
I got a job in the city.
Bad news - I'm fitting exotic tyres and run flats.
Good news - I get 25 bux an hour.
Bad news - I work four and a half days a week.
Good news - I get time to work on the GTR.
Bad news - still on about the same wage due to day pay as last job.
Got a job though.
Still kickin'.
:-D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
