Greetings :)
  • Name: Keagan
  • Model: R31 Nissan Skyline GXE 3.0 EFI
  • Year: 1989
  • Price: $800
  • Odometer: 350,XXX
  • Colour: White over Gray
  • Engine: RB30E - Stock Standard
  • Exhaust: Stock Standard
  • Gearbox: Automatic
  • Rear Suspension: Standard
  • Front Suspension: Standard
  • Rims: Standard 14''
  • Mods:
  • Future:
Edited by GXE23
https://www.sau.com.au/forums/topic/424690-1989-r31-skyline/
G'day guys and thanks a million for the friendly welcoming, I'm sure I'm going to have a brilliant time on here!
Plans for the car are underway right now. Keeping it pretty Granny spec to be honest but plans and things I've purchased for it, thus far include:
  • White LED Parkers
  • Chrome Checker Plate Floor Mats
  • Cannon muffler with dumped tip (Less ricer looking)
  • Interior White LEDs under the foot-wells wired to a switch/battery
  • Pioneer Headunit/Cadence 6x9's & 6.5'' component speakers/500W Kenwood Amp/300W Kicker 12" Sub & 4 Gauge wiring kit.
  • White LED map/interior lights
  • White LED dash/odometer lights
  • Nite-Shades/Lightly tint tail-lights
  • Paint rear garnish and grill-bit in Gloss black
  • Add a K&N Re-usable filter
  • Add 8mm Eagle Ignition leads
  • Service with - Penrite HPR30 Oil, NGK Spark plugs, Bosch Fuel Filter & K&N Oil Filter
  • Cheap wheel covers for the time being / Looking to get 17'' 5 spokes of some sort down the track
And that's about it for now. Plan to give it a really good cut&polish and then go over it a couple times with a chipstick and turtlewax ice etc etc
Thanks a billion again for the friendly introductions guys, looking forward to having so much fun with this being my 8th car. ;)
Spent the arvo in the garage, removed and tinted my tail-lights with a bit of VHT Nite-Shades, and removed the rear garnish, gave it a thorough clean whilst the garnish was off and have sanded, primed and painted it in a nice black gloss. Tomorrow I'll get out and give it a few more coats, then sand it lightly and cut and polish it for that nice factory lookin' finish.
Also received parts in the mail today, was stoked!
Awesome have taken a look on Ebay, but no luck finding any as of yet, will keep a regular eye out though! Thanks for the idea, as small as they are, they will make a massive difference in the look for the car itself!
second thing I did after gts wing :)
How long ago did you purchase them? Either I'm a real tool and cannot find them, or their possibly no longer on Ebay?
I've searched under countless titles both including "R31" "Clear" "Side" "Indicators" "Nissan" "skyline" just to name a few combinations, but can't find anything as far as clear indicators go for R31's, only able to find R32 / R33 / R34 small bubble shaped side indicators >.>
Little help? :wacko:
oh my bad you need to search for BMW-E30-3-Series clear side indicator... they fit r31 rather than r31 indicators
I just had a quick look and there's some on e bay... don't pay over $50!
good luck :)
I hope these are the right ones, going off the general shape of them on the picture, I'm guessing they are? Would these here be a direct fit without and modification to the body needed?
http://www.ebay.com.au/itm/83-91-BMW-E30-3-Series-Clear-Lens-Front-Bumper-Lights-2Dr-/300601673496?pt=Motors_Car_Truck_Parts_Accessories&hash=item45fd418718&_uhb=1
Never mind. Found a pair of Clear indicators for the front bumper and a pair of clears for the sides. Thanks a million L33SH for putting us onto the BMW E30's, you've made my weekend a bit better!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
