  • Replies 88
hey a quick question to anyone reading this with adj cam gears (OS Giken in particular) how many degrees is each index mark on the slider?
ie. 1 point (index) = 2degres???????
oh and a dummy one to make sure, turning anti-clockwise on the adjustments is retarding while clockwise is advancing? - just to be sure!
Oh and while pulling it all apart i found the cause for my inlet being so tight! i just wonder now whether that was the main problem with the GTR cams for not holding idle!
Hehe,
My car has been sitting too long for my tastes and I've been getting lots of static from the wife about how "everytime you buy something, that car doesn't run afterwards." I'll go back to the RB26 cams in a bit, but I think I'll get some adj. cam gears and get an ECU remap first.
-Matt
haha Matt i know your pain, but i have a nagging girlfriend instead of a wife.. so i just threaten to dump her if she says anything bad about my car!
But like you my car has sat too long and i cant afford a retune or PFC at the moment.
oh and the reason it was stiff, was actually due to the camshaft clamps being on the opposite way around, as in they needed to be turned 180deg. they were in the right order, just not the right direction!
the worst part is i put them back exactly they way they were on in the first place! so some idiot once put them on the wrong way, anyway they are smooth like butter now, and im sure that the GTR cams would probably WORK!!!!!! but i have already promised them to someone and spent the money on adj cam gears!
So looks like ill get my car running and give the GTR cam thing another shot sometime in the future.
So good luck to all those that are still going ahead with it. you will prob find it works regardless of you ECU type.
just some thoughts on the topic (i'm trying to think of anything to try to alleviate this problem)...
some guy on the forums put NA rb20 cams into his car (232deg and 7.8mm lift) and he had no problems with the install from memory. so the altered duration isn't the problem. what i don't understand is that its happening for these particular cams when normal aftermarket cams work in the rb20??
out of curiosity, what spark plug gap are you guys running? maybe it needs 1.1mm gap to work properly? or if you are running 1.1mm already (most aren't) then you might need to go to 0.8mm... hmmm?? yeah you're right i'm probably talking about unrelated shit!
my cams should be here by the end of the week...! its gunna work!
Waz.
well im beggining to think that maybe the reason mine wouldnt hold idle was due to the increased effort needed to turn the engine as the inlet cam was very stiff to turn.
If it wasnt that then it has to be the standard ECU.
I'm pretty sure all my cam brackets went on the way they came off and I did not see any markings on them (are there any?) The strange thing is that when we first started the car after the install of the RB26 cams it actually DID idle. On the drive home is when it started to freak out and during that time I popped off an intercooler pipe. I'm thinking it's the ECU. I still don't understand how Tomei, HKS, etc.. are able to run if the RB26's won't. I mean afterall the RB26 cams are really quite similar with higher lift.
If someone with the standard ECU gets this to work, please enlighten us.
-Matt
what about chaning just the inlet cam? maybe it will idel? or just the exhaust cam?
if Tomei cams work there is no reason the rb26 cams shouldn't work there is something being overlooked here...
Couldn't agree more -
all down to one thing I reckon - Managment, or the lack of. A programmable computer is a 'must have' I think
Chris
will be interesting to see......
I think the issue everyone was having is that there is more air for every revolution (having greater lift on the GTR cams) being pumped through the engine,and the stock computer can't work it out.
Would be intersting to see if the programming would still work at WOT, as it would be relying on the airflow meter signal to determine how much air is going in..........
Will be good to find out if it is the case
hmmm the air still needs to come from somewhere and its through the afm so i am assumeing the thing should still run....
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
