  • Replies 70
was nice to meet Jag33...yeah it was Daniel...:P...anyway hope u had fun cause i sure did and will be up for it again....my time was nothin like urs but now that i actually know what im doin and how them bloody lights work i might be able to do better next time...
So what did you end up getting Daniel? :P A High 13 or Low 14? 12?
best i got last year @ heathcote was 13.8 @ 101.5mph, only had cat-back exhaust then a pod and [boost maybe 12psi max]. I probably should have turned the boost DOWN more, too much wheelspin in 1st gear :D
You should be able to get to mid 13's fairly easy with that Terminal Speed! I am hoping for mid 13's on my next outing too...
Da bunny in da grey GTR at calder hjahaha BIGGEST BLEEDER MICROSOFT SALES PERSON EVVAAAAAAAAAAAAA
haha, bunny...
nah, all da boys were out wif their vls. my cousins cousin was dere wif his yellow bt1. they were sik. but i didnt see many skylines running fast times? i think the fastest skyline was still slower den the slowest vl turbo.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
