We need little name badges so we can tell who each other is :thumbsup:
Maybe ask #@RUSH is he can print out some names on vinyl to stick on anything? even a shirt really lol,. Would be best wit hUsername & Real Name
"Captain Nastro - Nick"
^This guy is a genius
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
