how can i achieve around the 260kw atw's mark with a rb25det? what mods will i need done to do this and mods to make it reliable?.
1 how much power can the internals handle in rb25dets?
2 how much power can the fuel system handle? pump,injectors,regualator)
3 what hp figure is the standard t3 turbo rated at?
cheers.
It is VERY important to get a fuel pump that not only supplies the appropriate pressure and flow, but is also less likely to fail than the std item. The fact that my car no longer has it's original motor is a testament to that.
But in order:
If tuned correctly, I would suggest that they're capable of reliably making 400 engine hp.
Injectors will prob be maxing out at 350 engine hp, regulator....dunno....pump piss it right off.
Firstly it isn't a T3. It's a specially made unit manufactured for Nissan by Hitachi. It does use a T3 flange and this is where the confusion comes from. I believe it is rated at about 340hp.
Adrian
Heavy duty Clutch - $1100
Front mount intercooler - $1500
Fuel pump - $450
injectors (altho its been proven to get 250kw's out of the standard injectors, get bigger for reliability) $1000
Turbo: HKS 2540 will get you their with good tune, or if you want a more power go for the GT3040 $1500 - $3000 new or second hand.
high mount exhaust manifold: $2500
maby aftermarket head gasket. (depends on what boost you want to run) $400
Ecu : maby power fc - $1200
wastegate - $500 - $800
hks exhust cam gear - $250
3" exhaust etc: - $1500
Thoes prices are just guestimate. theirs most likely stuff i've missed
get a set of cams, tomei ones 256 - 260 or whatever the ones sydneykids says to use :)
this will increase torque over the entire rev range and on boost too
the 2540 will just be laggy, if you want the same power level get a r33 highflow it should match the power of the 2540 without the lag.
the hks3040 brand new from nengun is around 2700 not including delivery. look at a gt30 with a gcg manifold instead, probably better and more cost effective, get an external gated turbo too. or even a trust kit which includes turbo, wastegate and manifold. i wouldnt just stick to hks just cos
ecu probably power fc, hand controller and boost controller kit
other ones like wolf3d dont use air flow meter so that solves your air flow meter problem
stock r33 gtr intercooler should be ok for upto 300rwkw vs brand new aftermarket one
youll need a new or good/better clutch twin plate as stated
i would do injectors and fuel pump and fuel regualtor to be sure to be sure, saves stuff going bang
also you *may* need a different air flow meter, depending on how much boost you run, the stock 33 one will max out and only show 5volts and give the wrong reading the ecu so the ecu will underfuel
i dont believe head gasket is needed, check out below threads
http://www.skylinesaustralia.com/forums/sh...ight=power+rwkw
http://www.skylinesaustralia.com/forums/sh...ight=power+2530
for some previous configs and power outputs. get a full exhaust, hiflow cat, hiflow dump and front pipe
my info is mainly from searching on here and reading up and learning myself so some of it could be slight out or incorrect, sorry if it is
Guest INASNT
cheers.
Like anything the rb25 will last as long as u treat it well. Dont drive full throttle and like u just stole it all the time and it will have a long life.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
