Posting on behalf of a mate
Hes in the market for a track car and some times drags, hes currently tossing up between either the 32 or 33 GTSTs.
The car will be completly stripped and will run a mild RB25 and manual in which he already has in his shed.
Brakes will be upgraded to 33 GTR items again as he already has them.
Is there any benifets going a 32 or 33 over one another? knowing they will both run the same engine and brakes plus be stripped?
Is it to easy to say the 32 will be better due to the lighter weight to begin with?
any other benifets from one or the other?
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/
stripped down there will be bugger all weight difference between the 2. the 32 may be a fraction lighter, but not much. it's only about 50kg in road going spec, so stripped down i'd say it would be less, given that some of the weight difference between a 32 and 33 is from the heavier rb25 engine, gearbox, etc, which would all be going into the 32 anyway. but the 33 has better suspension as said, and it may well be a bit more aero dynamic, so faster.
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6845838
I have a R33 GTS-T, just finished it actually. I have now tracked it twice and gotta say it's a great thing.
It's not overly powerful (280kw) or light for that matter (1300kgs) but it's fairly quick for what it is. (1:44 EC full circuit)
It's something I could drive all day in an enduro or similar, very user friendly and easy to pedal.
I always thought the 33 were the ugly ducklings, but I've really grown to like this one.
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6845863
Thanks mate
I took him in my full weight R33 GTR 333kws at mallanats and he wants something nearly comparable.
So his goal would have to be around a stripped fully car with near 400kws and drag slicks i should imagine to be comparable?
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6845998
A stripped GTS-T would be almost 200kg lighter than a full weight GTR so there's no way he'll need 400kw to be comparable.
I would think 300kw would be enough given the weight difference. All he'd need to do is work out how to get the power through two wheels effectively.
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6846015
R33 far better car in just about every way bar looks. If you have a tuff looking 33 than that's a win all round. I have a r32 race car and have owned quit a few road going 32 but I wont buy another one. R33 or 34 is the go.
You will never get a gtst to put power down the way a gtr does. My tuner runs the fastest track skyline around our area and while that is a gtst and eats all gtrs he has driven Plenty of gtrs and can't believe how fast they accelerate out of corners ect. It's just different and can't be matched.
  • Like 1
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6846510
The RWD Gtst can get the power down just fine when the suspension is done right.
I wouldn't say the R33 has massively better suspension, its improved but still has the fundamental problems of the R32 still.
The R33 body shell is only beefier in the rear strut area. Otherwise they are very much the same as the R32.
After doing brightys R33 I think the 33 has a lot of potential to be a good thing.
https://www.sau.com.au/forums/topic/424987-32-vs-33-gts-t/#findComment-6846919
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
