It's caused by having too much negative camber for the type of driving you do. If you drive in a straight line most of the time (ie, not on a track) then you cannot have much neg camber or you will wear the insides of the tyres. At the rear, the problem is made worse if you like to spin them up.
And yes, this is caused by being too low. As you lower Skyline rear suspension you automatically gain neg camber. You need adjustable polyurethane upper inner bushes at a minumum, or adjustable upper arms.
This has been discussed at great length, including recently, including the legalities of the various options. So have a look around.
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6847416
Have this same problem, but didn't realise until recently.
I dont track or spin the rears, just normal daily street driving. My car is lowered and has -2 camber from what was on my receipt when i got my wheels aligned after the drop.
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6847803
yes there are shops and i cant suggest any cos im in sydney but i just want to reiterate that if you want to stay lowered then you will have to use adjustable bushes to eliminate camber OTHERWISE if you purely want to adjust coilovers to eliminate camber you may be going back to stock height.
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6848616
How much am i looking at for adjustable bushes, and do most mechanics/tyre places have them readily available?
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6849069
Pretty much no mechanic or tyre place will have adfjustable bushes to suit any car (except maybe Commodores!) in stock. Pretty much any tyre place cannot be trusterd to spin spanners so discount them immediately. Pretty much any mechanic could order bushes in within a day. If you fit bushes you need a set for the upper inners and a set for the inside/front ends of the radius arms as well. This will cost you a couple of hundred.
The arms need to come off and a press used to get the old bushes out and new ones in most of the time. The labour will probably end up costing more than the bushes.
Adjustable arms that have rose joints on the end (like the GKTech ones) are not street legal. Adjustable arms with bushes (such as Hardrace ones) probably are.....but you might be in for an argument with a cop and then the pain of getting it defected and having to clear the defect anyway.
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6849111
Rose joints. Heim joints. Ball joints. They're metal on metal. Really good location and articulation, but......extra NVH, they wear out because they get grit in them, they are an instant defect should a cop see them, and sometimes the cheap ones are shit quality and break.
Hard Race is a brand that does adjustable arms and the like but with hard rubber bushes in them instead of the rose joints used in most adjustable arms. There are one or two other brands out there that do the same. Bushes are squidgy material between two shells to allow arms etc to have some compliance instead of hard metal-metal contact.
https://www.sau.com.au/forums/topic/425081-tire-wear/#findComment-6849766
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
