This is an ad for a friend (its an amazing machine). Please contact him and not me.
Item Description: Pulsar 93 Jap Spec SSS converted AWD / GTi-R RB hybrid
Kilometers: 138000
Item Condition: Stunning in most respects, see extra info for more.
Reason for selling: I want someone else to continue the dream
Price and price conditions: Offers (around $12K)
Extra Info: This was once another members project car, started in 2004 and completed the major modifications in 2007. I bought it in 2008 as I had gone as far as I could with my U13 FWD Jap Spec and this seemed the logical next step. Since buying it in it's "project" state I spent a further $9K in sorting out and strengthening the diffs and the gearbox. I also redid the intercooler and put on a GTi-R bonnet. This allowed me to put in Air Conditioning (recently serviced 3 months ago for $650). Interior needed to be redone with new carpets etc as some parts had gone missing in the last "strip out".
The car was off the road for quite a long time and lately the car has been driven on weekends mostly. It has never been my daily driver but saying that it drives perfectly in traffic etc and I am still smiling after a 2 hour expedition to Geelong.
I just paid the rego in Feb and realised that I am being selfish for holding on to it as someone else could appreciate a bit of PGA history and give it the love I wish I had the time to give it. Therefore "this is the year I sell" and it will also be the first time in 10 years I have not owned a Jap Spec SSS.
Here was the write up from the previous owner that captures perfectly the essence of why this car was built:
A significant amount of money was spent on the car, I knew back when I started I would never make any of it back, it was planned to be a all-purpose daily driver.
Two vehicles were used in the creation, a fully intact RB spec GTi-R purchased for this purpose, and my original '93 model Jap spec SSS.
Neither of the vehicles were crashed or damaged before the conversion.
Specs and parts are as follows:
- GTiR RB Drivetrain/Gearbox (with front mechanical LSD), in conjunction with standard middle/rear LSDs. This drivetrain in conjunction with the suspension kit and better weight distribution (compared with a standard GTi-R) results in significant power oversteer, especially in the wet, so I would suggest a more experienced driver.
- GTiR Model SR20DET straight out of above vehicle with 80,000km at the time of the conversion. Engine is otherwise unmodified.
- Turbo is an GT2871R (bigger 440hp model) with HPC coated exhaust manifold and turbo ex housings.
- APEXI AVC-R Boost controller.
- Brakes are standard GTi-R brakes running Bendix ultimate pads all around.
- Walbro GSS341 fuel pump
- Exhaust is custom dual 2" system, a split dump pipe into 2" straight from the turbo to the rear mufflers, i.e. 2x catalytic converters, 2x resonators, and 2x mufflers, this was done to quiten down the system while trying not to restricting flow. The bumper had modifications done for the dual mufflers, in a "tasteful" way (i.e. no cannons), atm there are no tips on the mufflers.
- Full GTi-R whiteline works suspension kit with Koni yellow adjustable shocks
- Cusco front strut brace
- Nismo front brake master cylinder brace
- Full respray in Turbine Mica Grey (a heavy metallic-pearl grey colour used on the higher spec Commodores/HSVs).
- Webasto Hollandia Sunroof (Stratos 700 model) with rolled edge roof (no ugly 'rubber trimming' like on most aftermarket sunroofs)
- Genuine GTi-R front aluminium 'scuff plate'
- N15 SSS Wheels (Lenso P600 are currently for sale separately)
As it was never completed this vehicle is NOT ENGINEERED. It is however still registered and had a roadworthy after the completion, but it is adviseable that it be engineered if it was desired to be a daily driver (especially for insurance purposes). The car has current Victorian registration and insurance until January '14.
For the bad points, well of course the engineers. There is also a rust bubble patch on the leading edge of the GTi-R bonnet as well as a paint blemish on the top of the drivers side C Pillar. The 2 front seats are dirty / marked (but I have put covers on them). There is no head unit or amp (but the speakers and tweeters are in there). The car could do with a dyno and tune as the Apexi has never been fully tuned / set up. I did have it mounted "stealth" in the sunvisor though.
The previous owner and I totalled up the money he had spent to date and stopped when it hit $42,000, even things like the sunroof was $2500. Considering I have done most of the hard work (apart from the engineering) and spent an extra $9,000 you can see that this car has had some serious $$$ spent on it. With that in mind I am looking for $12K.
https://www.dropbox.com/s/lf4b0li0t4a2hha/IMG_5370%20%28Small%29.JPG
https://www.dropbox.com/s/fy3jqqtj4naq3ea/IMG_5374%20%28Small%29.JPG
https://www.dropbox.com/s/u0v0gryqqmbw619/IMG_5373%20%28Small%29.JPG
https://www.dropbox.com/s/o9ldxumxedrn30c/IMG_5356%20%28Small%29.JPG
https://www.dropbox.com/s/pghrs02hdh3maog/IMG_5401%20%28Small%29.JPG
https://www.dropbox.com/s/smay7vmjixx10o3/IMG_5405%20%28Small%29.JPG
Happy to chat on the phone 0438 543 738. David.
  • 10 months later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
