Howdy,
Up for sale the following bits purchased with project car which are no longer required most bits are new and never used unless specified. Also have a heap of bits from R32 and R33 wreck so let me know if you need anything.
6 boost genuine steampipe exhaust manifold to suit RB25
BRAND NEW (manifold was built to suit RB25 in R32 - compact design - but will be prefect for any R32 or R33 with an RB25)
Work of art to Suit RBb25 head stud pattern
T3 flange
50mm v-band external wastegate flange
NEW never used
$1100 plus post these RRP $1400
YELLOW JACKETS coil pack set R33 Series 2 (no ignitor box) - YJ-RB2526-S2
Straight bolt in for RB25
NEW never used - they have been fitted but never fired up. pic is not of actual coilpacks as I didn't get a photo of the actual ones
$350 + post
Turbo Beanie
Keep the heat where it should be - suit T25-T3 small T4
NEW never used
$60 plus post
Nissan Skyline R32 Reat strut brace bar GTST GTR - Looks like a whiteline?
Used in good condition
$100 + post
Nissan Skyline R32 Front strut brace bar GTST GTR - Also Looks like a whiteline?
$100 + post
Front mount intercooler 600x300x76
Perfect for the front of any skyline
Finished in black in great condition looks like new, has been used.
$100 + post
R32 GTST Gearbox and tailshaft combo
Has redline oil, taken out of vehicle with 145xxxkms on clock
$500 pickup only will throw in heavy duty clutch for extra
$100
ID1000 injectors 1000cc top feed injectors with injector plugs - and brand new Billet fuel rail combo
Complete setup $1100 good for Pump fuel or E85 capable of 350rwkw with supporting mods
NEW never used
$600 for injectors + post
$150 Fuel rail with -8AN 90degree fittings + post
Pro Flow inline fuel filter also available pics up soon.
Drift Steering wheel deep dish blank horn button
BRAND New in the plastic
$80 + post
Oil Cooler with Relocation Kit and all braided lines and -AN fittings kit everything you need to make it work - even filter
Brand new unused, bolted up for trial fitement, will fit straight into an R33 or R32.
$450 for the lot
RB25 cam covers with -12AN fittings on breathers.
Fittings are with $100 alone!
$150 for both covers and fitings
RB25 Coilpack cover
$50 + post
Innovate Afr Wideband Air/fuel Ratio Gauge
Comes with everything you get inthe Box, offers dark face or
silver face option
NEW never used.
$200 for everything
RB25 R33 Silicon radiator hoses
Top and bottom hose
NEW never used
$20 + post
Oil Filter sandwich plate + all braided lines and -AN fittings.
Got your own core? Use this to plumb it up.
Has been used but in good condition
$80 + post
RB25 R33 engine mounts
Used good condition
$80 pair + post
Exhaust heat wrap roll
NEW never used
$50 for the roll enough to do manifold and dump pipe.
R33 AC compressor
Used and no longer required purchased with a spare engine.
$50 + post
R33 power steer pump
$30 + post
I also have a range of R33 and R32 bits so PM me if you need anything. Will post more items soon.
Located in Sydney Hills Area prefer pickup will post at buyers expense, all prices negotiable although please no
time wasters - time is precious!
  • Like 1
https://www.sau.com.au/forums/topic/425521-r33-r32-performance-parts-and-wreck/
But wait there's still more...
Surge Tank Setup with GENUINE BOSCH 044 700HP external pump complete mounting bracket ready to go.
BRAND NEW never used, fabricated from aluminium looks neat as - not ebay alloy. BYO hoses and your good to go with this one
$320 plus post ono
Cometic stainless steel gasket to suit RB25
New and never used
$50 posted
JJR steering wheel quick release
New and never used
$50 posted
Injector Loom to suit RB25
Great condition plugs are fresh as.
$40posted
GLOW SHIFT electronic Fuel PRESSURE gauge 52mm
New and never used comes with all senders and wiring
BLUE led - look awesome day and night
$75 posted
GLOW SHIFT electronic OIL TEMP gauge 52mm
BLUE led
$65 posted
GLOW SHIFT electronic OIL PRESSURE gauge 52mm
BLUE led
$65 posted
GLOW SHIFT electronic WATER TEMP gauge 52mm
BLUE led
$65 posted
$250
SILICON Radiator Hoses
NEW never used - $20 + post
$80
R33 clutch fan
Great Condition
$80 + post
R33 space saver spare wheel
Great Condition
$50 pickup only
RB25 forward facing plenum
Great Condition don't need as have a plazmaman
$300 plus post ono
R33 stock plenum and runners
Bare plenum no injectors of fuel rail, don't need as have a plazmaman
$50 plus post ono
R33 Series 2 stock coilpack loom/harness
Great condition
$50 posted
R33 radiator shroud
great condition no cracks or breaks, just needs a quick clean
$75 pickup
R33 Series 2 Door Trims
Front pair only in good condition
$60 pickup only
Blitz 52mm Boost Gauge
Great condition $55 posted
Bilet Fuel Rail with -6AN fittings as above
NEW Never used
$120 posted
R33 RB25 CAS crank angle sensor
Great working order removed from running vehicle.
$110 posted
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
