1998 JZX100 CHASER TOURER V- SERIES II, FACTORY MANUAL. 96,000klm
This car is in really good condition and is awesome to drive, certainly turns heads whenever it gets driven, I'm only selling it to finance another car project i have going on at the moment. Would have love to keep it but I want to finish my Bimmer and I have too many cars.
Full Factory Aero (series 2 front lip, side skirts & rear valance)
HKS Hipermax coilovers (base height & damper adjustable)
HKS Exhaust (can provide standard exhaust)
HKS Super Suction Intake Pipe
HKS Intercooler
HKS Boost Gauge LED Tail Lights
Cusco Strut Brace
18" AVS MODEL T5 wheels with Kumho KU36 Tyres, tyres are about 6 month old
Clarion Touch Screen Double DIN DVD unit with amp and new Hertz speakers all round
In the photo of the interior you can see white marks on the steering wheel, i have a new steering wheel ordered and will be replaced before the car is sold
Price: $17,500
If anyone is interested, I can be contacted either via email at [email protected] or by PM, though i dont always get the notifications from my PM so i may miss it for a day or two
https://www.sau.com.au/forums/topic/425769-1998-jzx100-manual-chaser/
  • 3 weeks later...
Price adjustment $15,500
I've found and engine and some other parts for my m3 at the right price, but I need to move this on first to fund it :( So I'm most certainly open to offers, but I dont have time at the moment to get a RWC so it will be sold with out one.
Edited by MookRG
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
