Hey guys
What fuel pump(s) do you guys run?
More in the way of performance and upgraded setups..
Ill be looking at doing my fuel pump setup in the near future, and thought I'd get some feedback on what everyone has used,good/bad etc
Ill be running new lines from tank to the engine, and a surge tank.
As for pumps, originally was thinking of leaving the walbro as a intank feed pump, up to x2 044 bosch externals pumps.
But also think i will look into possibly running one big high flow external pump instead of the 044's
Thoughts, feedback, opinions.
https://www.sau.com.au/forums/topic/426768-fuel-pump-setups-what-do-you-use/
If need fuel pump to be done, and in sydney I'm the man for the job I could help you if needed cheers.
stop spamming dude.
back to OP, really depends On your power goal what setup you run. I would have thought stock internal pump would be fine when used with external pump and surge tank
edit. just read you already have a walbro, so disregard
Edited by superben
I use a pro-fab under car surge tank with a insomnia feed pump and 2 044's. 1 feeds into the standard feed line, the other into the retun line and I ran a new return from the FPR to the surge. Pretty budget system as I used MPFI hose and not braided or pushlok.
Ran 1 x 044 and maxed it at around 357rwkw on E85, it was in tank, quiet and reliable...
Now I run a pier burg lift pump, surge tank, twin 044 feeds, twin -6 lines to rail, twin returns via fuel cooler... Epic setup!!
Got pics of the fuel cooler?
Some shitty pics in here mate -
http://www.skylinesaustralia.com/forums/topic/358438-34geeteetee-daily-track-project/page-33
You could have had a squizz yesterday but i was a lazy kent and didnt introduce myself :P
I bought my car with an In-tank Warlbro 255 and an External Bosch 044 in the boot with a surge tank as well. You can hear the pump in the car, but its not annoying, sounds cool imo haha. Car makes 330rwkw, not sure what the limit of the system is as I bought it like this.
If you were going for over 350kw, I'd get a surge tank, lines and lift pump/in-line pumps for the peace of mind.
Otherwise I'd just run a nismo in-tank. Plenty of people making 300kw+ with just that and decent injectors, myself included. Check out ss8gohan's r34 GTR build ;)
okay cool,some really good feedback thanks guys.
seems everyone mostly runs the twin 044's.
no one here ran an aeromotive inline yet?
yeah when its ready it will able to run some decent power, depends how hard i want to push it, but it will defintely be over 350kw without stretching limits.Ive allready got my lines setup at the rail, got them feeding both ends and returning from the middle.
I like the looks of that fuel cooler! good thinking, might look into one of those.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
