For anyone who remembers the old HPI VHS' (and later DVDs) from the late 90s and early 2000s, I found this American version using the exact same footage and script, FTW!!! - Was this done on purpose by HPI to sell to an American audience, or did some yank just decide to remake Australia's greatest car mag videos for his buddies in a language they would understand :P (in either case, what's wrong with the Australian accent?)??? Check the links out for both and post your thoughts:
ORIGINAL AUSTRALIAN VERSION:
REMASTERED AMERICAN VERSION:
http://www.dailymotion.com/video/xmn0qv_high-performance-imports-v5_shortfilms#.Ubqz6Zz4GOc
From memory it was Ben Ellis, now, former HPI Editor and owner of Otomoto.
He was the one who first narrated the HPI videos (The voice in the original AUS Ver.)
I'd assume him being the former HPI Editor (does not work for HPI anymore).
When HPI did the re-release they had to find another narrator... Emilio Seballos...
HPI made the best magazines of all, and he's Australian not American
Do you watch the second link? The American narration is in that one - you only heard Australian because you only watched the first clip :O
Hmm interesting....
back in the day they came out in both, the pal version had Ben (Aussie accent)
The NTSC version had the American bloke
I only remember Ben Ellis and his monotone voice :P Don't remember there being 2 versions when I bought the HPI v.2 and v.3 VHS' at the 2000 Melbourne Auto Salon.......ahh the memories......(I've still got em if anyone's keen for a vintage watch though I don't know of anyone who still has a VHS player!!)
Only the PAL standard version was available in Australia, as we use the PAL standard video system in Australia
America uses the NTSC standard video system and that's where the NTSC version went
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
