hi there, i have a "00 rsfour stagea with the rb25NEO and i am trying to figure out wether i've blown my piston rings or turbo.
i've searched but havent been able to find anything about this so if theres a thread about this please just send me a link or tell me where to look.
now, i was driving along the freeway at around 130km/h and doing a few pulls and playing around with the gears and spooling the turbo up as it's my first turbo car and had only driven it from where i bought it so far. as i pulled of the freeway and stopped at an intersection without any warning the car just starts blowing smoke and ran rough as anything and just felt like it was stalling and starting up again so i limped it downhill to a carpark and shut it off. when i started it i held the revs around 3,000rpm and it blew smoke like crazy but didnt feel like it was misfiring at all, but as soon as the revs dropped below 2,500rpm it would completely drop like it was stalling and starting again and i couldnt bring the revs back up.
i have the turbo off and just played around with it and there is a bit of play in the shaft and when i spin the the blades i can see oil coming down the blades from inside the turbo.
so i really need help with this before i fork out money for a turbo or rings.
any help is appreciated
https://www.sau.com.au/forums/topic/427036-rb25neo-blown-turbo/
you guys don't think if he did a seal in the turbo it would put the oil into the air and into the cylinders/plugs and it would smoke and run rough? My R33 did the smoke/run like a pig thing when my fuel pump shat itself and it leaned out and destroyed the ring lands on the pistons(amongst other things) but that was white smoke, what colour smoke was yours?
cheers guys for the other ideas, havent even looked at the cooler yet, but when i took the turbo out one of the cooler pipes had oil all around it. and my fuel was on empty pretty much so i could've done something to the pump
also it was blue smoke pouring out the exhaust
yea had the cooler pipe off for a while and cleaned it up when i did. but all through the cold side and into the throttle body there was a fair bit of oil so im hoping its the turbo, if it was seals the oil would be on the echaust side of the turbo and not through the intake? that make sense or am i just rambling like the rb noob i am? :P
Is there bucket loads of oil or just residue?
Your blowby vents back into the intake on stock cars and does cause the whole intake to look rather grubby over time.
If you were mopping a litlre of oil out of the cooler pipes i would plug up the oil feed and return to the turbo and do a comp test to make sure the engine is ok. If its only a whole stack of gunk stuck to the sides of the pipework i would put my cash on it being a turbo.
How wet is the turbine wheel of the turbo? is it soaked with oil?
turbine was clean but i also didnt get the turbo off for a few days but just spinning it in my hand i had oil coming down the blades. and it looks pretty gumky but not litres at all. it didnt drip out of the pipes or anything.
im gonna try get a new turbo first get that back together then do a comp test as im getting a bit lost with all the parts in my garage.
I would say you just blew a cooler hose off somewhere
Cause if the turbo blew an oil seal it wouldn't idle rough but just blow smoke and if the turbine wheel was dry wont be a turbo seal as oil won't dry up
And a light film of oil in the intake of the turbo is normal blow by
i think the smoke was caused by the turbo seal (just going with the general advice i've been getting). not saying your wrong by any means because im not really in a position to doubt anybody haha. comp test definately if it keeps smoking up im just really hoping it is the turbo
Come on guys really? It would never blow blue smoke unless there is OIL IN THE COMBUSTION CHAMBER........ A blown cooler pipe will NOT cause oil to pour into the cylinders, only a few things could cause the problem stated and judging by the description it sounds like a blown piston, however u start with the cheap stuff,
Pull out the plugs first, look at the condition of the plugs, if the are covered in oil it will confirm you have oil getting into the engine before the intake manifold, if only one or two plugs are covered n oil then it an internal issue localised to those cylinders. If you hav an exploded plug then its lookin bad for the motor, Next do a compression test, if all cylinders come up good its more likely to be turbo or valve stem seals, start with those simple checks then let us kno what results you get
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
