Hi All,
I bought some ARP main studs for my RB30/26 about 5 years ago from Spool and recently started building the engine.
The block was sent away for machining with the studs and I requested that the mains girdle be torqued to 65-70 ft lbs with ARP Moly lube for the main tunnel honing as per the torque specs in this thread http://www.skylinesaustralia.com/forums/topic/388491-help-what-tension-arp-main-studs/?hl=arp+main+torque#entry6196886
Got the block back and torqued the girdle down to 70ft lbs to measure the bearing clearances with plastigauge. Clearances were fine so final assembled and then found that I needed to cut one of the 3 long studs down to clear the shaft that passes through the RB26 sump. Released the girdle, cut the appropriate stud down and re-assembled back in its hole. Torqued the main bearing ladder back down and one of the shorter studs sheared before it reached 70 ftlbs !
Managed to drill the bugger out but now I'm left wondering why exactly it sheared. The threads in the block were clean. The stud was hand tightened first. ARP moly lube was used in assembly and the main studs were tightened in the appropriate order with a good quality Snap-on torque wrench.
Is it just a case of 70ftlbs is too much or could it be a faulty stud ?
Should I replace the whole set as a precaution or is it safe to just replace the single stud do you think ? If thats the case does anyone know the ARP part number for one of the short studs ? It would appear to be M10 x1.5 where it screws into the block, 105mm long and the nut end would appear to be a different pitch thread - possibly M10 x 1.25
During my searching I've found torque figures of 55, 60, 65, 70 and 73-75 ft lbs for RB ARP main studs so some clarity and real world experiences would be nice.
Edited by mambastu
I'm told by ARP that there isn't an official main stud kit for the RB30 and the stud kit arrived in a bag so Spool must make up a kit and unfortunately there wasn't a spec sheet with them.
Incidentally the 73-75 ft lb torque figure came from your excellent thread at http://www.skylinesaustralia.com/forums/topic/378823-engine-internals-comp-ratios-general-info/?hl=%2Barp+%2Bmain+%2Bstud+%2Btorque if you're able to edit that at all (you may not be able to due to its age) it could help people with future searches. :)
  • 1 month later...
There has been a batch of arp studs floating around snapping. I usually torque them to factory nm +10nm and NEVER have a issue however a couple of years ago we had several engines primarily rb getting snapped studs on factory or below torque settings. We werent the only people to of suffered this. Try getting arp2000 or l-19 studs. Secondly DO NOT CUT that stud down. Have it machined off at a machine shop. TBH ive NEVER had any clearance issues with this stud so many have
When was your torque wrench last calibrated? Just because its a snap on wrench it doesn't mean its even close to being with spec. They are a pain in the ass to calibrate and get parts for too.
Seriously consider having it calibrated again before you do up another set of studs, lest you start breaking rod bolts next.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
