Hi guys,was wondering on a rough power estimate someone could give me on my new set up before it gets tuned.. Im hoping for around 350-400 im hoping this is possible (rb25 det)
Mods include:
Apexi power fc
Arp head studs
Slide industries gt35r turbo kit
Z32 afm
Turbosmart afpr
Bosch 750cc inj
Excedy h/duty clutch
Split fire coil packs
Hks fuel rail
Greddy plenum
Bosch 044 (x2) fuel pumps
3l surge tank
Cometic head gasket
Avcr boost controller
Any advice would be appreciated :),keep in mind this is a fairly standard engine and im new to the forced induction world (355 stroker man) cheers heaps :)
350kw should be attainable (470whp).
the trick is making sure you have no boost leaks and have the right size pipes from air filter to muffler tip.
please check out the RB25 dyno thread, a few minutes read will answer this question.
welcome to the dark side.
Result will be the same as any other GT35 setup really, it's the turbo that will dictate the power as long as the exhaust can flow.
Things like a fuel rail, FPR - don't give power, in fact they don't even offer much of anything. On a stock motor, overall, risky business pushing towards 400rwkw
Also you might find the clutch wont last too long as something else to budget for.
You'll find that patience will help a great deal. Hang back a couple of months and read all the popular threads in this section (just keep an eye on the first page and passively read whatever comes up).
After a couple of months you'll be a lot more confident in your parts selection and how to set things up.
Probably the best read for you right now is the Kando dynamic thread. It shows what a stock RB25 can get away with when you set up a reasonable turbo.
Enjoy and feel free to PM if you feel your getting lost.
Thanks so much i really appreciate it.. Everythings bolted on just need to find someone to tune it now :)
A good tune is critical - post up your location and you might get pointed to a tuner who knows his stuff (and RBs).
Grafton nsw :)
Damn that is tricky, i dont know any RB tuners anywhere close to you but hopefully one of the other guys will have some input!
Best to hire a trailer and go for a trip to see the banana benders up north :)
Lol all class!
Was told matt spry from pitts on the goldy is the go when it comes to tuning :) am just about to go pick up a good set of axles and springs and im a make me a trailer ;)
Have heard that name bouncing around before! Lucky basterd having the skills/tools to make a trailer :woot:
  • Like 1
Awwwe shit... Email that pic to trent whyte... Guarenteed a job in the fab shop at mercury :P
Lol, be careful what you say about shops online mate! Its one of the forum rules and it is enforced at times.... I laugh at generally everything but it only takes one to take offense and report ya.....
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
