Be careful going higher because if you go too high the stock shock will be at its full length of travel and won't work at all, it will bounce everywhere. My friend and I tried it on a commy ute and the rear lifted off the ground when braking hard
Well now they're getting cheaper at the bottom end, I think a grubby C34 would make a great softroader, basically.
Some slightly larger diameter all-terrain tyres (235/60R16 looks good and fairly common) would get a little clearance but at the same time would need a little more height to help guard clearance. I was thinking along the lines of stiffer springs and some strut top spacers.
I actually had a think about this as an option for a touring wagon/beach buss/camping wagon.
My stag is reasonably low. Honestly I don't have too many issues with driveways, speed humps or parking bollards (my front lip will clear a standard height concrete parking bollard by 2-3mm). We started taking it camping and day trips.... perfect for a blast up the east coast (Tassie) then cruise into a camping spot, most of the camping places are down dirt roads, on sand and washed out potholes. I'm surprised were I was able to take it..... the center diff lock and snow mode is great in rolled gravel or sand, just as long as you straddle the rutts :yes: . A couple of times I could actually go places the big 4WD guys couldn't go :woot: under fallen trees etc.
We ended up buying the missus an xtrail, suits her gutter riding duties better ( :no: my poor volk GTC's).
Long story short:
I was going to space up the sub-frames and between the shock and shock tower. Throw on some more off roadish taller tyres. Then use some aftermarket arms with slighlty longer stroke shocks/springs.
J
Hmm, I have some spare front shock absorbers for the stagea lying around. Theyre stagea specific ones and theyre slightly longer than GTR shocks. Longer stroke to the piston.
I guess theyre for what youre talking about. Most stageas are/were family wagons and snow cars, not sports cars.
Your biggest issues will be keeping the correct geometry if you change the relationship of factory pickup points/shock-spring length. The rebound geometry past horizontal gets squew wiff pretty quick.
If you space the sub-frames the same amount as the shock spacers, it keeps everything relatively sock for geometry/bump-steer etc If effect a 'body' lift.
XRATED, thats the same kind of thing that got me thinking, I've crawled into a few places it by all rights shouldn't have been, it seems very competent getting around on gravel and sand, through muddy paddocks and up and over stuff.
I think the rear subframe could be spaced down, isn't the upper arm in the front mounted to the chassis though? so I'm guessing that wouldn't work for the front. Ours seems to have a little negative camber on the back at stock height so I'm guessing a little bit of lift via spring/strut there wouldn't hurt, front I'm not so sure how much you could lift without going into positive camber.
Clearance wise I think with early bumpers, no skirts and no lips it wouldn't be too bad, sump does hang pretty low but could always run a bashguard tied back to the crossmember.
Edited by floody
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
