That's exactly what i said. Take it for a day out at basky and you will forget about selling it pretty quickly. On that note i am hopefully going to have my car tuned next month and will be organizing a quiet track day for a bit of a "run in/learn how to drive your car again" session if anyone is interested. ie. jack lol.
I'll be down in tassie on the 27th-28th of July and should be at the track on the 28th if anyone else is keen ;)
Wtf why are basic car trailers like 4-5k. That's like quarter of a Evo 8. That shits not happening
That's why I ended up going for one of Az's trailers, not much more than a stock standard POS trailer, but 10x better by far. We saw a number of wooden based trailers which were still a fortune, and basically useless and horrible for what we wanted.
At least the resale value should still be pretty high
Az's trailers sound nice but I simply can't justify it. Brody thinks 2k if we were to build, have a contact on the steel, that's more like it. Might be able to put slide in cage sides on one and use it as a yard trailer also.... Get rid of parents box trailer kill two birds with one stone. But paying 4-5k I won't be.
Well i dropped into pro auto today only to find that they're closed till Thursday!!! So i hope he won't be too busy when he's back and can fit me in cause im keen to get on the track!
Glad to hear you finally got motor back. :yes:
QUESTION - for our local super sprints, hill climbs and time attack event, does a unregistered vehicle require a log booked cage? my Bond cage can't be log booked, I see on the mainland this seems to be the case. all because its not road registered?
  • 4 weeks later...
Just a heads up as some people seemed interested in heading out, I'm all set to go for a track day this Sunday (28th July). Would be good to see some of you guys there :)
Hopefully it doesn't rain too much.. I still don't have windscreen wiper arms!
Clandestine, Rainx is you're friend!! 10 bux a bottle works wonders. I'm still a little way off, have actually got a bit done recently but awaiting for a few things to turn up and still yet to order some others... Made my canards yesterday and today, about 10 hours from start to finish. Thinking October, fingers crossed
Would love to come but turns out when I got my car tuned the other week it still has oil smoke issues on boost which need sorting out. :verymad: Was considering a tester at basky to see exactly how bad the problem is but don't think I'll be ready for sunday.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
