Anything I should know about doing this? Take off the wipers and then under the screws? The screws are a funny profile on the head, sorta square shaped. Are they screws or a type of automotive fixing? Just unscrew them? Just don't want to get half way through and find it's harder than it looks......
Thanks guys.
It's very easy.
Your on the right track. Remove the wiper arms first.
With the clips they're automotive fixings. Be careful when removing.
If I remember correctly it's a half turn and lift.
Remove the rubber strip at the base. There will be "T" pieces holding it on. Just stretch one way and lift off.
It's likely going to be gungy under there . Mine was dried up mould but cleaned up easy and looks great.
Ps. If you happen to loose or break one of the fixings O'briens will have some :)
Mine were easy and never looked like breaking.
When Obriens came around to put my new OEM windscreen in he was surprised that I hadn't broken or lossed any.
That's why I mentioned being careful
Any dramas leaving the plastic panel off for a while whilst exposed the rain? I note that there is a large opening under the grilled section and I'm unsure where this goes to. I presume it drains as normally water would go through the grill and into it?
After. Some surface rust which I'm wondering how to deal with. I guess to do it properly I'll have to mask, sand, and use some sort of rust inhibiting primer (which hopefully will roughly match the grey). Bottom winscreen wiper nuts are corroded so I'll loosen them and try and make sure they no not sieze and the bolt thread is still OK.
So, under that plastic panel lurks all sorts of mud and dirst and grime which idealy would get cleaned out every couple of years. Another area I've noted that traps a lot of grime is behind the tail lights. I'll get onto this fairly soon as it looks filthy in there.
I've actually covered the car with a cover whilst the plastic panel is off as I think water will get into the engine bay without it.
  • Like 1
Oh yeah, the rubber strip does need to come out and I found the only way to do this was to use a flat screw driver blade and carefully pry out the fixings. By the look of them they just press back in so I think this is actually the way to remove them rather than just my hamfisted ways. They are actualy integral to the strip so you can't actually get to them as they are housed within it. Anyhow hope this is helpful to other in the future.
So.......the Autobarn guy didn't really inspire me with a lot of confidence with his advice so I thought I'd come here. The question I have is how I deal with the rust. Most of it is surface but there is one small spot (say 5mm diameter) which looks a little more serious. I'm thinking I sand back the surface rust, dig out the 5mm spot, and then spray with.....?
Clearly the black cover will hide any paint I put on there but I'd prefer to keep it looking as factory as possible so can anyone recommend a product that will match the underbonet colour for a silver GTR and that will be appropriate for addressing the rust as described. I think there are paint products that actually turn rust into something benign, but are they only available in black?
Thanks.
Thanks.
fill and paint over? also, no idea what product this is but just an idea, even if this product is black then you can just paint over it again...right?
Kill rust is a clear solution you could try
http://www.wattyl.com.au/en/find-the-right-product/exterior/Metal/Prepare/WattylKillrustRustEeter.html?preview=true
Supercheap sells white kill rust epoxy enamel
Edited by BstewyR33
Went the easy / smart solution and took it to Micolour to get it sorted properly. Had some other minor blenishes attended to whilst I was there and also got the front guards spaced out for tyre clearance without losing my guard liners.
Looks too good to put the gutter back on!
I get it back today and will get her cut and polished next week after the rear diff rebuild.....Look out bank account.
    • To be determined, Luke, to be determined. 😁 Definitely the car
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It’ll be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
