Hey guys
I've had my 33 since september last year, very standard and in epic cond.
Only mods at the time HKS cat back, hybrid front mount and turbosmart plumb back.
My main goal with the car is to make it responsive as possible
After my last car being a fail in most cases (listening to people that had no idea)
I talked to Powertune Australia, discussed the options for what im chasing in my budget to achieve what im after
they did me up a full quote and i told them honestly that i can get most things through my work for better prices and they were totally understandable
overall there customer service is amazing and from the results Ive seen with friends cars and on forums ill definitely get my tune done there.
here is my mod list of what i plan
- Garrett gtx3076 .82
- powertune highmount manifold
- tial 44mm
- walbro 400lph in tank
- deatschwerks 1000cc drop in injectors
- Haltech plug in, wideband, boost control and map sensor
- drop in camshafts 256*
- Forward plenum
and all the other misc stuff around it.
Here is the car when i first got it
After the first couple of weeks the car was due for its 100,000km service
it kinda blew out and we did a bit more then just a service..
- Apexi headgasket 1.1mm 87mm
- arp headstuds
- tomei poncams
- genuine water pump and thermostat
- godspeed forward plenum
- turbosmart supersonic bov
- cooling pro radiator (gates lower hose. gktech top hose)
- exedy HD clutch
- Blitz front pipe
- catco highflow cat
- custom cold side cooler pipes
- d1 spec breather tank
- greddy catch can (200 series fittings)
Heres a few photos of the car now with a new set of wheels and some tein super streets :D
Since then ive just been saving for the rest of parts and we are ready to go!
gtx3076
exhaust manifold
haltech
injectors
fuel pump
ill do an update when the rest of the parts are purchased and going on :)
thanks for reading!
https://www.sau.com.au/forums/topic/427514-dylans-r33-gts-t/
What sort of boost do you want to run?
Its hard to say as not too many people opt for the GTX series turbos, most stick with the GT series or recently the Force Performance HTA series (see 34geeteetee or lithiums threads).
Have a read of Angrys build thread, he was running a gtx3076r for a little bit before selling it for a twinscroll gt series.
http://www.skylinesaustralia.com/forums/topic/426934-angryrbs-r33-street-sweeper/#entry6888986
Its well known that at around 18-20psi you will see 300rwkw +- out of a GT3076r 0.82 with streetable response.
My GT3582r powered rb25 makes 330rwkw on 23psi, but its laggier than a gt3076r obviously. The GTX series turbos are laggier than their GT equivalents but they flow more, so ide say easily 300rwkw at those higher boost levels but its unfortunately going to be a bit laggier than a Gt3076r.
Also check out 6boost, ETM and Brae Fabrication for manifold choice, all steampipe like powertunes. Braes one of the newer lesser known producers but he has some epic designs, high and low mount.
  • Like 1
For a power figure ill let the tuner run what ever boost he wants, for everday use probably 14psi for low boost and whatever i can run for high boost
i've had standard turbo cars before, nothing like this car. if i seen 300+ id be cheering!
i was considering the gtx3582 but i wasn't keen on that much lag and down the track im going to be running a ethanol sensor for e85 aswell
my tuner told me id need to run at least -6 fuel lines under the car for fuel supply if i went with that turbo
for something that probably wont see a track i couldn't justify it
ill look into those manifold thanks dude!
I think the engine will be the limiting factor, I was using a stock manifold and at 16psi it was making 320kw's, with 20psi thru the midrange the car was angry, rolling on in second at 4000rpm it would leave solid black lines, third had the back end wiggling .. and that's not pushing the turbo at all.
other things id recommend
E85 walbro intank ( cheap and easy drop in)
Xspurt 1000's ( not too bad seeing you have ffp) mine at 70% with 320kw
gate off the housing
100cell cat
( just a thought but what about a TS manifold and swap the rear for a TS? )
100cell cat
Yours was on e85 with that power wasn't it?
That fuel pump I plan on getting
1000cc injectors are on the list
The cat I've got is 100 cell as well
Gate of the housing?
And as far as the rear housing ill probably leave it, I don't have any doubts ill be happy with the car
I've never had a fast car before and I'm not cheaping out on anything
So it should drive the way it's meant too and be reliable
He just means run the external wastegate directly off the turbine housing, rather than off the manifold. Better boost control and you can often also save a little bit on the manifold. All thats needed is for a pipe to be grafted and welded onto the turbine housing on a correct angle. pic below shows correct angle, where you can see the gate pipe is flowing straight up off the turbine housing where the gasses do not have to make any sharp or awkward turns.
(pic from and of nytskys engine build thread)
Thanks for explaining
Honestly I've never seen it like that before but I understand the concept completely
Ill defiantly consider it :)
  • 4 weeks later...
Hey guys
Not much to show, most parts are ordered
45mm turbosmart hyper gate
Walbro 400lph e85 in tank fuel pump
Full braided turbo line kit including drain
Haltech pro plug in, wideband kit and boost control module
Turbosmart fpr800 fuel pressure regulator
Powertune high mount steam pipe manifold
Genuine gaskets and exhaust studs
Only thing I'm waiting for is my 1000cc deatchwerks injectors
Getting keen :)
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Sorry it's been so long without a post guys been insanely busy
Went to powertune about 8 weeks ago
On 98 octane, 21psi it made 309.2 kw at the wheels!
Very happy with the result the way the power comes on is very smooth and controllable which is good as its my first car
Now I've got a lay by for a e-flex sensor and going down the track of e85 and dual maps :)
  • 7 months later...
Hey guys!
It's been a while been flat out with work and stuff
The skylines going really well, the only problem
I WANT MORE POWER!
I've picked up a second hand block, considering building it and a head.
I'm uncertain what path to take
Is the car going to be reliable stock on a flex tune pushing more on e85?
If so does anyone know what kind of number I'd be looking at??
For now I'd love to do upgraded fuel and run a flex sensor to get more out of the current set up
But long term I definitely want a fully built motor :)
My goal would be to max the gtx3076 .82
After recently going for a drive in a friends gt35 powered 33 I don't think I could deal with the lag lol
  • 3 months later...
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
