This might seem like an obvious question for some but I have never done it before so just getting a heads up before I f*k something. About to pull my engine out and sell my shell with gear box still in the car as that is fine and engine is screwed. My question is once I have unbolted the gear box from the engine and pulled the engine out will the gear box mounts under the car (R32 gtst) be enough to support the box or will a jack need to placed under there to support also. Im hoping the mounts will be sufficient as I need to move the car with the box still in it.
Thanks in advance
Luke
You need to have something under the bellhousing to hold the box up after it is no longer being held up by the engine.
Once the engine is out, you will need a block of wood of the right length to jam between the engine crossmember and the top inside of the bellhousing so you can wheel the car around without having the box drag on the ground. Obviously enough you cannot leave whatever blocks you originally put under the box in place while the engine was coming out and still move the car!
Ok i do this every day now and could do it in my sleep, no wood or blocks or special wheels needed. dont unbolt the box from the motor, it will make your life hell with the starter motor and top gearbox bolts, its 1,000,000 times easier to pull it out with box attached and drop back in with box attached and wiring done.
start with the engine wiring loom, if your leaving the loom on the engine dont bloody touch it, just unblot it from the ECU and with a helping hand will pop thru the firewall easy enough. or you can unplug all the connections and hang the loom off to the side.
remove the gearstick from the box if manual, or disconnect the levers underneath if auto.
open the fuse box cover in the engine bay and with a 12mm spanner unhook the starter/alternater loom from the fuse box so u wont have to unhook any wires from the box or engine, take out the 10mm bolt lower down from the fuse box holding the engine earth in place on the chassis and unplug the rest off the loom at the plugs near the fuse box.
next is the turbo piping and thermo fan, then radiator, power steering pump and A/C compressor, leave the p/s pump and compressor on the engine just undo the pipes and wiring connected to the pump and compressor.
Heater hoses in the back and other bits attached to the motor at the top like vac lines and throttle cable.
DONT FORGET THERE IS A CONNECTION GOING TO THE STEERING RACK, it will snap easy so becarefull when unpluging it.
next get under the car, remove the exhaust first, then the tailshaft. after that undo the 2 14mm bolts holding the engine mounts in place from the bottom, if you remove the single 14mm nut at the top you might snap the engine mounts in half when pulling the motor up.
now grab a jack and jack it up underneath the gearbox, undo the gearbox crossmember and shes just about ready to come out.
do a final check to see if any more wires are still attached to the engine that are supposed to stay in the engine bay then grab a chain to hook onto the engine ( one near the back and one near the front ), if you dont have a chain a seatbelt will work fine so long as you tie it on correctly ( one thru the rear of the exhaust manifold and one thru the front of the intake )
jack it up slowly and jiggle the motor around slightly to get the engine mounts to pop up, once the mounts have popped up, check you have unplugged the steering rack plug on the drivers side, then one more check for things attached to the motor. jack the motor up some more untill the gearbox touches the trans tunnel then you can remove the jack underneath the box, then its a simple process of little up, little forward, little up and again little forward untill the bottom belt tensioner clears the rad support, once its cleared just keep jacking up and up.
when you start pulling it forward more you will need the help of a friend to make sure the box isnt swinging around like crazy.
done, takes me a total of 1 hour and 15 mins this way, trying to undo the starter motor and top gearbox bolts might take you an hour by itself.
  • Like 1
I'm printing this sh*t.
Hey Mungy, do you use car ramps to raise it? Would have thought that stands wouldnt be that stable or do you just sit it on the wheels and jack it up when your working under there.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
