Just go to your nearest radiator repair shop. Its not rocket science - they either hold water or they don't - I've never come across a bad one yet...If its bad enough you'll need a recore or possibly a new stocker.
  • 3 weeks later...
Thanks for all your replies. I have tried ADRAD's local guy but he is having trouble as well. He tried rebuilding mine and also sourcing a replacement but no luck so far. I have found one through Nissan (genuine) and they need to ship it from Japan. The other option was to get one built $$$. Anyone else had experience with imports that they could shed some light on my situation.
Cheers,
Perry.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
