On any car of great worth, I believe that it should be insured comprehensively, rather than at market value. A GT-R will be such a car.
On a car worth less than $10,000 but above $4,000, I might be tempted to insure it at market value - but maybe not.
If the car is worth less than $4,000 I might only pay for third party property insurance.
Sum Insured/Premium ratio depends on too many variables.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6911463
Well I have a 93 R32 GTS-T coupe. Insured for $11,500 (most I could get it insured for)
I'm 21, lost my liscence once before and I'm paying $866 a year.
With JustCar Insurance.
Hope this gives you a rough outline.. :)
Edited by Zrobe
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6911573
so comprehensive insurance would be insuring it at an agreed amount?
how much did u insure your car for Terry?
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6912227
Agreed value can be a bit of a personal question for some, me included.
I could be wrong but the rarer and more valuable the car, the less likely people are to disclose.
Feel free to prove me wrong.
oh... ok
no worries then. was just checking out to see how "insured value" relates to "annual premium"
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6913536
Generally speaking the greater the agreed value, the higher premium.
In saying that, the bulk of the premium often relates to the type of car (GTR=high risk), age of driver and suburb its garaged. Suburbs can make a pretty big difference.
Insurers will also increase/decrease premiums based on their experience as well as the types of risk they want to insure.
Years ago nrma jacked up my premium on a 200sx from $2.5K to over $4K. No change at my end. I went in to talk to them and the lady said that instead of saying no they will sometimes increase premiums significantly for cars they don't wish to insure.
I went elsewhere.
Edited by Cherry Racer
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6914175
ok maybe i should rephrase...
if your car is rare and valuable, are u able to insure it accordingly to how much u paid for it...mods and all? or will the insurance company tell u how much its worth?
Heavily depends on the company offering the policy. The majority of mainstream companies will probably exclude highly modified cars, let alone insure them for an inflated sum.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915010
think i came across a company that specializes in insuring jap imports, cant rem name though... anyone knows abt it?
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915071
A lot of the younger generation (myself included) tend to insure with just car insurance, if that's who you're thinking of.
Shannons and a few others I can't name off the top of my head offer decent insurance too (In terms of recognizing import, rare or collectable cars and modifications) but unless you're 25 years or older they won't cover you.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915329
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
