  • Replies 63
Can anyone explain the duration to me??
Duration of a camshaft is how long it keeps the
Inlet/exhaust valve open for. So if you look af a 360* wheel and you have 260* cams, the camshaft has to go around 260* before the valve closes again. Lift is how far the valve opens as in height. So if standard camshafts lift is 8.5
And your aftermarket camshafts lift is 10.25
Then obviously the cam lobe is going to push the valve down open further by 1.75 which there for increase's air intake to in most cases create more horsepower. :)
Just a basic run down if you can't get your head around it I can be more thorough.
Cheers Josh.
which 260s did you have ? would be awsome if you have before and after dyno charts to see the difference between the two cams ?
There is no real difference loaded up on the dyno. I've seen a back to back, graph actually looks pretty close.
Same as -9s and -5s on the dyno, they don't look worlds apart in response or anything.
But the difference lies in the transient response or on/off throttle on the dyno and that's where things were noticed. Also dependant on the headwork that's actually been done, that compliments the cam setup, so it's no one singular thing
If the change was same setup to same setup and the only change was cams then it would been interesting to see the difference
I've seen on my 34 the difference from going to type Rs from type Bs and it was a fair bit, same peak power but every thing happened 800 rpm sooner give or take
so for my 6266 turbo (medium size single turbo) which already has a lot of grunt up top, would benefit from type R cams or there abouts, small duration 9.1 lift, to help spool and bottom end response
wonder why so many people go type b then
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
