  • 3 years later...
  • 2 months later...
...and learn nothing? Thats how you get through life is it? Just never done it on anything post 1977.. something tells me procedures may have changed 30 years on. Not afraid to just give it a go but anything to make a job easier is worth asking about. I have no doubt you have the knowledge but no need to be so arrogant about it. Didnt know forums had a Dont know, don't ask, dont try policy
Edited by c34Florry
Changing plugs is heaps easy. If you need pictures you probably shouldn't be actually doing it.
a mate and this thread taught me to change the plugs in my rb,
everyones at a different point on a learning curve, you at one point didnt know how to either so no need to be a wank about it.
nevertheless i use bcpres-11 gapped at 1.1mm
works plenty fine for me and actually fixed a misfire issue so yeah, happy hunting!
  • 1 month later...
When i removed the plastic cover covering the loom and plugs, the seal around the plastic cover was really brital and broke off, i assume its for sealing off any water intake so next question is has anybody had this same issues and how did you replace it. Also th metal peice that hold the ports for the coils to plug into was broken? Where the fourth screw belongs i dunno if its supposed to be like that or no? Also just thought id add that th plugs i removed were NGK R- PFR5G-11 a bit different i thought.
Cheers if anyone can help
Heres a pic of the metal part that is broken
Edited by adamRB
  • Like 1
yeh, the sides of my valleycover were really brittle the first time i changed my plugs, and broke off. Not an issue though, and as previously said, just dont go about pouring water over your engine lol.
Never took the metal bit out that held the coils:\ didn't even know there was one lol. Arent the coils just screwed down with 2 screws?
Also, as said, use a torque wrench to prevent threading lol. I slightly threaded one of mine, not causing any issues but really careful now when i change em (i still dont use a torque wrench oops)
  • 3 years later...
torque settings for spark plugs in an alloy head should be no more than  23NM maximum, when brand new plug this will give proper crush gasket "squish" and ensure a good seal without damage to the plug or the head.
this torque setting doesn't seem like much but a preset plug tool can be purchased through specialist suppliers that sell to motorcycle mechanics and or speedway enthusiasts, i have a KINCHROME branded one for my 2 stroke race bikes and it has saved me a fortune in replacing cnc machined heads from being stripped when they are over $2500 per cylinder head and you have 4!
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
