R33 Series 1
The motor and gearbox on this car is in excellent condition only thing damaged was the side of the drivers due to accident on the track hence trying to salvage. Everything is still working on the car and it pulls 340kw with dyno sheets. Car still drives fine. The car also still has 2 months rego remaining for anyone interested in the shell. Parting everything
R33 RB25 Series 2 Motor Engine rebuilt with forged pistons $1200 - No Coilpacks
EMS Stinger ECU
Damper Master Coilovers - $700 1000km use
Lenso D1R 18" Wheels
1200cc injectors
Garret GT 30\76R Turbo - $1300 1000km use
Nismo r33 Cluster $350
Greddy LS intercooler kit - $500 20km use like new.
Tripple plate clutch
Manual gearbox Series 2 - $1000 perfect condition
Front bar $150
Rear bar $150
Tail Lights $200
wing $100
Side skirts $100
CD player surround $70
Centre console $80
Front seats $150
Rear seats $100
Boot hatch $80
Skyline rear centre garnish $50
Door window $100 each
Window regs $100 each
Tail shaft $120
Starter motor $100
Front and rear Brake Calipers $350
Alternator $100
Brake rotors x4 - $200
Hubs $300
Rear cradle $50
Front lower control arms $70 each
Seat belts x 4 $150
Passenger door card $80
Passenger side window switch elects $50
Window switch surrounds $80 each
Steering surround $50
AC control unit $80
Window wipers $20 each
Side mirrors $90 each
Fuel cap $20
Fuel flap $60
Bonnet latch $50
Boot latch $50
Power steering reservoir $150
Top dash AC vents $20 each
Turbo Lines $40
ABS Box $200
Glove box with working latch $50
Fuel Pump $50
Fuel pump cradle $75
Antenna $75
Lock set (steering lock, door locks, boot lock with key) $200
Passenger side headlight $100
Power steering rack $100
CAS $100
VCT Solenoid $70
All Prices are Negotiable ! just want to get rid of this shit
O0hhCCB.jpg?1
3CPICFv.jpg?1
R34 GT 2 Door N\A Auto series II
Car is complete no damage. Silver in colour.
Xenon Headlights - $900complete set no scratches perfect condition
Complete Doors - $400 each
Mirrors - $100 each
Boot + Spoiler - $350
Rear Bar - $100
Front Bar - $350
Side Skirts $200 a pair
Tail lights - $400 Pair
2 Side guards - $400 Pair
Front seats - $400 pair ( drivers minor wear n tear )
Rear Seats - $100
Air con pump - $120
Brake master cylinder - $200
Glove box- $100
Intake Air Box K&N filter - $120
5 Stud - $500
RB25DE Motor $800 - missing manifold and intake pipe to airbox
Auto transmisson $200
Xforce exhaust system $400
Things sold - Bonnet, Jet washer , manifold, intake pipe, cat converter
All Prices Negotiable. Need space.
  • Like 1
R34 bonnet,jet washers,manifold,cat converter,door window switch passenger all sold.
Alot of interests in the GT3076R kit on the 33.
Comes with manifold,gate,dump,intake pipe all customly fabricated
this set up made 340kw have dyno's as proof.
$1800
R34 Lenso wheels with 50% tread $900 18x10 +35 all round. Xforce Exhaust $300
Lenso D1R $800 18x10 +30 Front +35 Rears with tyres.
R33 Front brake set 150 ea or both for $250
master damper coilovers
R33 Greddy Fmic
Garret GT 30\76R Turbo Kit - Comes with dumps , fronts wastegate custom intake pipe pod lines etc. $1700
R33 Series 2 Gearbox
R33 Series 2 Motor Forged CP Pistons 1200cc injecters, Candy red covers
R33 Dash $100
R33 Fenix radiator
R33 Non rolling shell has 2 months rego remaining $200 or it's going to scrap metal
Negotiable on prices.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
