Sounds good. Plenty of laps to be had + plenty of petrol to be consumed.
You can have a second driver use the car on the sessions your allocated for $0 cost, so my Dad's going to have a drive.
Bring on the cold (but dry) weather for the turbos!
This is the email I got:
Hi Everyone!
Thank you very much for booking in for this weekend’s Advan Trackday at Winton Raceway – it’s looking to be an awesome day.
The aim for the day is to be relaxed and full of fun laps for all. Here is the itinerary for the day to ensure you don’t miss out on anything!
08.00: Gate opens
08.15: Sign in desk opens – come see us in the scrutineering/track marshal office to sign in
08.50: Driver’s Briefing
09.00: Track open
17.00: Track closes
Groupings – Depending on the final number of entrants, we will either be running 3 or 4 groups of 15 minute sessions.
Preparation – All “normal” preparations should be considered, i.e. Long sleeve clothing, helmets, a working car with no leaks etc. Fire extinguishers are not compulsory.
Driver Training – As a little surprise for you all, we will have John Boston available all day for personal driver training at no extra cost! He can ride passenger with you or drive your car if you like.
If you have any questions, please don’t hesitate to contact me via email or phone!
See you on Saturday!
Done and dusted . Had a blast.
Ad08R's are an amazing tyre. Gave so much confidence.
1.33.38 on a street tyre.
First time at Winton without ABS, though new splitter and wing mounting made up for that.
Juliette, how'd the R's feel on the BRZ?
Top day, kudos to advan/circuitclub for organising.
Weather wasn't ideal but plenty to time to try this and that.
Just wish my cv boot held up so I could burn up some laps with their whizzy new tyres they were loaning out. Next time!
more pics here:
https://picasaweb.google.com/100203254234701302909/AdvanDay#
msg me if you want any hi res ones.
Thanks for pics martin. Lol: you travel so much, have you checked the camera timestamps :-)
Due to gasket issue robbing me of a few sessions, didn't get a chance to make use of Andrew from traction tyres being on site but did get a brilliant session with John Boston from www.trackschool.com.au here's hoping Advan Australia / circuit club can become a regular calendar fixture
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
