Hi all, just letting you all know im in the process of making an airbox for my c34 as genuine nissan airbox is basically a mortgage and custom fabrication is harf to find. So far I just have a template made out of cardboard and will make it properly out of some plain black heat reaistant plastic.
When I go out and buy things I will put them up in here and let you know how I went about making the final product.
These photos are what im planning on making the final product look like so any thing you see wrong or needs improvement please let me know. All critisism welcome haha.
Cheers :)post-112770-13738833025429_thumb.jpgpost-112770-1373883287587_thumb.jpgpost-112770-1373883372235_thumb.jpg
https://www.sau.com.au/forums/topic/428717-c34-stagea-diy-airbox/
Alright so the airbox is done. Only took a couple of hours as you'd expect. And as usual the only things I used were
-heat gun
-$50 of plastic or acrylic from bunnings
-side cutters (clean cuts on warm plastic)
-right angle brackets from bunnings
-some nuts and bolts I already had in the garage.
Hooe you like my version of the d.i.y airbox
Yea I would've liked to have it clear but being a p-plater even just having it glossy the way it is will be enough for me to get in a little trouble so trying to keep it relatively low key, it also hides the intercooler pipes so it looks like it goes from the filter straight to the t/b. It's a very tight fit as well haha. Thanks :)
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
