Hi all,
Got the following two items for sale:
1. -Cat & back exhaust suit R33 GTST/GTS
-2.5" press bent
-Twin 3.5" tips (fills stock rear bar neatly
-Hi-flow cat converter
-Super quiet with minimal drone and nice sound
-Flowed~200rwkw see here:http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/?view=findpost&p=6401351
-Selling as I have changed to a hi-flow turbo and 3" exhaust
-$200 obo
2. -6xSard 540cc injectors suit RB25/SR20 (side feed)
-Brand new in box never used or open
-Complete with collars seals, connectors, everything needed for fitting
-Selling as plans with the car have changed
-$800 obo
Items located in Warrnambool Vic, prefer arranged meeting point/pick-up due to cost of injectors and size/weight of exhaust.
Contact phone: 04 3774 51 FOUR SEVEN or message me on here
Will upload photos if possible shortly
Cheers, Josh
  • 1 month later...
  • 1 month later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
