Hello.
Ive found a nice m35 3.5lt rwd
My questions are
What have u guys paid for these b4?
Chain tensioner- how many ks until it needs looking at?
How is the timing adjusted on these? Automatic or manually?
Where can i get a rear boot matt from?
Common issues...
Do these suffer the rear end issues the earlier m35s had?
Anything i need to specifically look at?
I know electrics can be a prick on these,
How common, and what sorts of failures have you come across?
Rear tyre ware bad? And is fuel really 11.5 km/100? (Of course there are many factors but as a general guide?)
If/when i get it, ill budget for this,
Transport (syd to melb -who have we all used)
Travel to and from on a plane
Spark plugs
Engine oil and filter
O2 sensor (what one do i use? 350z?)
Brake fluid - check brakes
Power steer
Flush coolant
Rwc, rego, stamp duty
Insurance
Epic alarm
Cant think of much eles to ask atm. Any info is great!
In terms of mods, i dont need power, torque,looks.
I want comfort and fuel economy.
Is there a nice set of coilovers that are quite comfy?
And is there alot to gain with exhaust mods. (Dont want it louder than it is)
Thanx all
https://www.sau.com.au/forums/topic/428945-vq35de-and-m35-axis-help/
Please see answers in caps. Sorry, not intending to interwebz shout, just easier for you too see and read ;)
Hello.
My questions are
What have u guys paid for these b4? WHATEVER ITS WORTH.
Chain tensioner- how many ks until it needs looking at? 250,000+ I'M GUESSING. DEPENDS ON SERVICING
How is the timing adjusted on these? Automatic or manually? AUTOMATICALLY
Where can i get a rear boot matt from? YAJ/STREETER/IM
Common issues...
Do these suffer the rear end issues the earlier m35s had? DEFINE ISSUE PLS
Anything i need to specifically look at? SAME AS ANY OTHER USED CAR
How common, and what sorts of failures have you come across? NOT PERSONALLY, BUT ENGINE CAM/CRANK SENSORS, INTERIOR SCREEN
Rear tyre ware bad? And is fuel really 11.5 km/100? (Of course there are many factors but as a general guide?) NO IF ALIGNED CORRECTLY, AND YES, I'D BE STOKED WITH 11.5. MINE DOES SHORT TRIPS AND IS ABOUT 14/100. ON THE FREEWAY A BIT BELOW 10
Spark plugs
O2 sensor (what one do i use? 350z?) GOING TO REPLACE ALL 4....? MIGHT GET EXPENSIVE....
Power steer
Flush coolant
Insurance
Epic alarm
Is there a nice set of coilovers that are quite comfy? READ WHAT YOU WROTE IN THE PREVIOUS 2 LINES - WHY WOULD YOU WANT COILOVERS...?
And is there alot to gain with exhaust mods. (Dont want it louder than it is) NO
Thanx all
In terms of coils, im thinking of shagged out stockies not being any good, due to age, kms, and conditions
M35 issues are rear cradle mainly. Turbo also but this is N/A
The screen is it a pixle issue, or just dies? Easy to come by?
And is the cam sensor a prick to swap or is it not too hard?
Bc coil overs is what most run when they get them. They aren't harsh, but if you can get your hands on bilstein shocks, you'll be pleased. There are a lot of options
Haven't heard of a cracked pm35. Some theory is that hicas increases the chance of crack, but overloading and rough roads stiff springs is a bad combo. It's a simple fix. Weld it if cracked.
The motor that makes the screen go up and down can be temperamental. Haven't heard of replacement, but wouldn't be simple
Easy enough for a confident home mechanic. Back of either head, and in the bell housing.
I need a bloody matt for the back.
The bulldogs claws dont like leather
There are few on importmonster about 60-80 plus postage. If not got to clark rubber and make one out of thin rubber. I think scotty nm35 got his made up if I remeber about a year ago if I remember correctly.
Keep us posted with how you go Chef.
I'm interested too, the simplicity of PNM35's really appeals to me as I don't drive in snow/icy conditions. Non turbo is a big win also given how "one of a kind" the NM35 turbos are.
Without driving one it's hard to know how they are power wise - reading the specs a bit more than the NM35's from factory but obviously a lot easier to pull more out of a NM35 without more major modifications (bolt ons, mainly).
My other concern is fuel economy. I used to get excellent economy out of my NM35 - just over 10L/100km around town assuming I was wearing my sensible pants and as low as 8L-9L/100km on the highway without air cond.
I think if I bought a PNM35 I'd be organising a remap for it so I'd be hoping that I would be able to get those sort of economy figures out of one.
:/ remap for fuel economy? Isn't it expensive just to do a remap for fuel economy? and you might not get what you'd be hoping for, wouldn't it be cheaper to get it gas converted?
I'm a 4th year apprentice, I also have another job, completely independent. I manage 250km to 270km for half a tank on average and the car is my daily, it's hell unpractical as a daily, but I love the car to bits reason being it offers soo much and for me they outweigh the cost of running the thing and I'm not just talking fuel economy. If I wanted a car that was big, fuel economic and would save more money compared to a PNM35 I'd be looking at probably a diesel wagon or an SV6 or something...
You'd probably save more by spending 100$ a week at Coles or Woolies and use the fuel discount rather than a remap or get another NM35 as the savings of fuel you get over a year you can budget for tubz? Then next year with the same savings you can get a couple AFMs as spares.
Not trying to talk you out of PNM35's but one thing they ain't is economic :P.
But on to the mechanical issues, the only issue I've had was a split CV boot, the rear diff was weeping but that was just a blocked breather I was told, and I've replaced the radiator. The car has almost done 144k kms and I've probably put about 10k kms on myself.
Edited by M35woah
Engines have become a lot more efficient, these things run wideband o2 correction... But it's still 3.5L in a 2 ton car...
Liquid gas conversion would be the go like Matt said.
SV6 isn't going to be any better on fuel, nor is the NM35. Even the missus A4 1.8t only gets around 9L/hundred on the hwy.
Just going on what Jasevr4 has stated what he got previously, and the SV6 is just going on redbook figures.
The figures that Jase stated put the PNM35 to shame, there is no way I can do 10L/100km around town unless freeway town.
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
