yep I have the entire centre console.
gtr peices sold yesterday sorry.
msg me on 0421551710 and ill send yiu pics of the centre dash
Hey Jarrad - maybe you could help me with the R34 GTT boost sensor?
Looks like this
Located at the back of the block and the tube to it is normally blocked off.
bonnet was damaged so we tossed it
pod box
http://m.gumtree.com.au/nissan-skyline-r34-gtt-pod-filter-box-cai/v?adId=1025086477#pod box
hey the sensor went with the engine sorry.
anything attached to the engine is gone
Hey mate
Steering Column Cover top and bottom pieces?
Boot Carpet pieces $50?
Also after a few random dash pieces
Cheers
Edited by green180sx
Is it a series 1 or 2?
If its a series 2, I'd be keen on the drivers side guard. In Adelaide, so would need to orgainse shipping but thats not too much hassle providing it can be packaged suitably
Chris
sorry manifold went with engine.
i think it was a 99 model, not to sure if it was series 1 or 2 but i can get you a pic of the guard.
swing me a text on 0421551710 and ill send you a pic.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
