Hi guys
Anyone out there actually installed these?
The rear mounts that push into the subframe MUST be installed a certain way up...(Jap instructions are not clear which way)
I will get photos up to explain asap....
Just wondering if anyone has the answer now?
Cheers
https://www.sau.com.au/forums/topic/428968-nismo-diff-bushes-install-bnr32/
This is what I am referring to...need to know the orientation of the mounts in the subframe
You will note one side of the bush has a different pattern cut out, of which one MUST be positioned at the top
Can anyone help?
Cheers
  • 4 years later...
On 7/25/2013 at 5:41 PM, $$slowmedown said:
Just spoke to Terry at Award diff and gearbox, bloody legend!!!
He confirmed that bushes must be pushed in with the cut outs facing out to the sides of the car
Not trying to necro an old thread, but this info is wrong. Since this thread pops up when you do a search, I'd figure I'd comment just in case anyone else is searching. Don't want false info being spread. The side with the half circles go up. The side that is grooved out goes down. Just like the OEM bushings. Although the OEM bushings have bigger cutouts than the nismo. I can post pics if needed.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
