Hi guys
Anyone out there actually installed these?
The rear mounts that push into the subframe MUST be installed a certain way up...(Jap instructions are not clear which way)
I will get photos up to explain asap....
Just wondering if anyone has the answer now?
Cheers
https://www.sau.com.au/forums/topic/428968-nismo-diff-bushes-install-bnr32/
This is what I am referring to...need to know the orientation of the mounts in the subframe
You will note one side of the bush has a different pattern cut out, of which one MUST be positioned at the top
Can anyone help?
Cheers
  • 4 years later...
On 7/25/2013 at 5:41 PM, $$slowmedown said:
Just spoke to Terry at Award diff and gearbox, bloody legend!!!
He confirmed that bushes must be pushed in with the cut outs facing out to the sides of the car
Not trying to necro an old thread, but this info is wrong. Since this thread pops up when you do a search, I'd figure I'd comment just in case anyone else is searching. Don't want false info being spread. The side with the half circles go up. The side that is grooved out goes down. Just like the OEM bushings. Although the OEM bushings have bigger cutouts than the nismo. I can post pics if needed.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
