Looks like an awesome time everyone!!!
I'm hoping to have my nugget done so I can join you all some time soon! :yes:
Didn't know you were on the SAU forums too.
More Evo's! Forum should be renamed Evos Australia :D
@Luke, That wallaby was waiting for you lol, didn't run across until you were closer
Haha, Im everywhere.. :woot:
still have a 1/3 of a tank left.
Was laughing at the GTI, pushed it all day and covered 350kms... DTE was still showing 400+ when we got home! I would have been on my second tank of ethanol by then haha
The GTI is awesome... Needs an exhaust, intake and tune though!
Edited by Tonba
Hopefully should have the video done by tonight chaps. I done around 2 minutes of it last night (Which still took from 6:30 - 10:30!) and was buggered and went to bed!
Looks good so far though! Still got a metric shittonne of footage to go through and chop up, etc.
10% intrest each week on repayments haha just kidding glade I could help
PM your bank details champ!
Hey glad to help.
Sounds like that servo guy was a cock!!
He was Okay, The female manager was the one needing some cock
yup cards are safe :laugh:
I know, wtf was with that.
saw it, thought, hes not going to go the other way, bet hes coming straight across.
corners were fun on the way back.
whats that at terry?
your organising a hill climb? ;) thatd be a dream come true! that was my local sunday drive!
Luke is handling the Mac Pass event.
Matt, Carmen and Luke are handling Hillclimb/s
Exciting year ahead! Terrific to see how active Newie and ACT are! You have our every support!
Was a great day out guys. Thanks for having us along. Not the usual pace that we keep around the mountains, but still a fun trip. Was great to put some names to faces. :)
Great to see you Tony - but we could have chatted more about what Qld and NSW are doing in future.
You the man! Looking forward too it!!
Except Benji.
:rofl:
Trivia...
At home, Maria's Bimmer does not set off the EVO alarm.
Nor does the Maxima
Nor does the Postie's bike
My GT-R sets off the EVO alarm.
Yesterday at the truck stop...
* Other EVOs did not set off the EVO alarm
* Harleys did not set off the alarm
* R33 GT-Rs and GTSTs did not set off the alarm
* R34 GT-Ts did not set off the alarm
* The BsB R34 GT-R V-Spec did set off the alarm
*** The alarm was set off by - you guessed it - the R34 GT-R V-Spec II Nur with again, an N1 block. So is it a particular frequency?
Trivia...
Nor does the Maxima
Did my Stagea set it off on Sunday ?
Then there was also the unmarked copper heading up to the meet that jumped out infront of you
Agreed, the run home was also good.
I looked in my re-view mirror when we were towards the bottom of the putty and there's Terry, must of really "tested" the Evo on the way back :)
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
