Hi,
At the moment Just an expression of interest as im unsure what i will be doing with this car.
The Car is a 1996 R33 GTR Skyline V-Spec
Always serviced and well maintained. running 98 fuel
Looked after by boostworks
just had them look over the car for any problems before selling and all came back good
Unlike most older GTRs there is no need to worry about the engine failing or factoring a rebuild etc as it has already been done and maintained by boostworks.
White
Forged Engine
Forged Pistons
Multilayer head gasket
ACL race Bearings
Huge Extended Sump
New Rings
Honed Bore
New R33 Crank
New Rods
Only around 19000kms old
NPC 5 button clucth almost brand new
800cc Sard injectors
Apexi pods in custom air box
Custom cold air intake
Power fc and controller
AVCR Boost Controller
JUN cam gears
Apexi front pipe, high flow cat and Titanium expreme exhaust sounds awesome!
Garrett -5 turbos
z32 afms
Apexi 100mm intercooler
Coilovers
series 3 front lip
carbon GTR wing plates
Carbon pillar
new gear and handbrake boots
Catch can
Apexi Boost gauge
White Nismo Triple Gauge and Nismo 320kph dash
R35 GTR rear badge
Enkie 10.5 x 18 +12 all round rims with excellent tyres and red light weight wheel nuts
Clear front and side indicators
CD player
Standard clean interior
Long Rego
Car currently makes 333kws at the wheels at 19psi.
Can make more but its my daily and never had a need to push it any further.
Runs and drives great. Clutch is easy for city driving.
Never had a problem with it apart from replacing the clutch
There is a dent on the roof which was there when i bought the car
Would lower the price if cat back exhaust wasnt wanted (have a jasma cat back to put on it) or if you brought your own wheels.
Probably missing other bit and pieces
Reason for sale is i have a track car now and want to put some money into that.
May trade for a V35 plus cash my way
$30,000
any questions plz ask
Edited by Adz2332
https://www.sau.com.au/forums/topic/429111-eoi-r33-gtr-v-spec/
I havent but i can grab you some decent ones on the weekend.
For now heres some crappy ones i took on the way to work!!
The steering wheel has no major wear marks and the seats have no holes etc
Better pics up this weekend.
Will take off $650 if the titanium cat back is removed and a JASMA stainless one put on
Will take off $1000 if you bring your own wheels
Price neg
  • 6 months later...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
