hey dudes, i am a bit of a lurker around here, so i thought i better put up my own car. i apologise in advance for some of the photo's. some are good. some not so much. well actually if we are being honest im have 4 weeks off work due to injury and am crazy bored haha.
i am coming up on 2 years off ownership next month. when i first got it :
i just fiddle for the first months and loved the shit out of driving it
then i did a drift day :
loved it. car was awesome and i didnt break anything.
then i put a roll cage and bride in. and did another drift day
532003_10150667603412956_1088294440_n.jp
549385_10150667598062956_1036924619_n.jp
by this point, i'd put 14/12kg springs and lowered it and all that jazzz, i had a fun day but the car sorta lost that feel that it had. oh yeah i also did this
spun on the entry, and as you can see went backwards in the wall. its kinda hard to explain the damage, but basically the wheel caught on the wall snapping the lca and doing a number on the front corner.
fast forward a long long long 12 months and it got a new turbo and 25 box and some other basics
521976_10200547355740049_43734131_n.jpgjust in time for the same day/track as i had the bingle the year before.
had the best time, wasnt without issue though, broke a drive shaft on the drive to the start line in the morning missing the whole morning session waiting for a mate to bring out a replacement. but after that it was on
733831_380158985431360_899865851_n.jpg553022_380159578764634_1393910352_n.jpg66851_10200906552684740_657703408_n.jpg554544_10200906554644789_103740824_n.jpgwas driving fairly loose as it was the first time in twelve months with a new power setup. i found out later it had a finger tight waste gate and a 190rwkw tune due to some time constrants leading up to the day. i had some pretty mad bind issues and a bent rack by the end of the day, but still manage to drove home. at this point i got poor and lazy missing out on a round of the state drift series. but i got it all back in time to do sprint day at symmons plains.
i dont have any photos of the this, but basically the night before i decided i want to have a crack! changed nothing at all, so still not front sway bar and mismatched 2ndhandies on the back. i had a fair bit of fun and ended up with a 67 flat around there. we didnt get a whole lot of laps which was a bit shit in the end.
around this time i changed the vskf's for a all time favourite wheel of mine
advan oni's! this turned out to be a love hate this but i rate muchly! at the same time this got new coilovers, drop knuckles and a proper tune resulting in 243rwkw!!! fun fun fun.
some where around here i test fitted my dmax kit
annnddddddd painted it sparkly pink!
which brings us to the specs list i guess
ENGINE:
RB20
TD06 l2 20g
stainless manifold
tial 44mm mvs
3' straight thru exhaust
GTR injectors
Z32 afm
GTR intercooler
random bitsa intercooler pipes
relocated fuse box
semi rewired
Suspension
front
GP sport G master 8kg
20mm longer lca
tein tie rods
tein tie rod ends
pbm rack spacers
s14 rack
eccentric solid rack bushes
GKTECH knuckles
PBM castor arms
r32 5 stud and brakes
rear
Gp sport G master 6 kg
cazman toe arms
china camber arms
PBM knuckles
GTR sway bar
Nismo 2 way
Driveline
exedy clutch
rb25 box
Interior
Bride zeta 3
keys racing wheel
ASD hydro
6 point cage
stripped sound deadening
sparco harness
Exterior
Club s lip
vanquish roof lip
dmax boot lip
4" twin pipes
wheels
work VSKF
17x9 +18
17x9.5 0
18x9.5 + 19
VS-SD
17x9 +22
Advan oni
16x8 - 1
17x9 +25
Volk GTC
17x9 - 6
Nismo LMGT2
17x9 +23
this brings us to the end of a long winded post i guess. right now the car is all good to go bar a small few things and i am just waiting on my hand to heal (work accident) so i can drive.
Future plans
oil cooler
gauges
recliner on the passenger side
autech skirts
get kit fixed
new exhuast
new front bar probably
find some one to led my tail lights.
Edited by Frenchie1001
https://www.sau.com.au/forums/topic/429206-c33/
  • 5 weeks later...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
