hi all i have some leftover parts from my s13
standard tail lights perfect condition complete with bulbs and all $70
180sx headlights with motors and covers in good working condition, $150
180sx 25mm widebody front gaurds in average condition$50
180sx bonnet in average condition very small dints and has been sanded for paint$100
also have a complete (front bar, rear bar, skirts) brand new never fitted supermade instant gentleman bodykit (not genuine) paid $900 take it for $700
OP6/ VQ30 turbo with hks 1bar actuator good condition next to 0 shaftplay $300
rb25 long motor with low compression 130-135 across all 6 has blow by issues still in the car running suspect just very worn not cracked pistons given the even compresion so could probs get away with rings and bearings rebuild$500
s13 sr20 non turbo motor was running well when removed from car comes with complete loom and ecu and auto gearbox$400
brand new never used greddy emanage blue $350 can have map sensor and r33 patch harness for extra $100 selling due to change of plans
black s15 factory wing with brake light and wiring$150
driftworks s13 rear lower control arms used$150
most parts are located in brisbane northside some are in bundaberg can arrange to bring parts down from bundy on weekends and maybe deliver to some where between bundy and brissy best bet to msg me and arrange from there
feel free to ask any other questions all prices are negotiable can text pictures of most parts if you want
would be best to call or text me on 0434 879 399 as im not on here very much
Andrew
https://www.sau.com.au/forums/topic/429539-qld-rb25s13-parts/
let's talk serious on the emanage blue...not the most cutting-edge pice of kit, but how much you really chasing for it and the r33 plugin harness?
feel free to make an offer still have all of this needs to go asap
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
