Still going just forgetting to update
08/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
10/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
12/08/2016
Squat   3x10 92.5kg
Bench  3x8 80kg
Row     3x8 80kg
Ohp     3x8 52.5kg
Rdl      3x8 92.5kg
Curls   3x8 17.5kg db
15/08/2016
Squat   3x10 95kg
Bench  3x8 82.5kg
Row     3x8 82.5kg
Ohp     3x8 55kg
Rdl      3x8 95kg
Curls   3x10 17.5kg db
18/08/2016
Squat   3x10 95kg
Bench  3x8 82.5kg
Row     3x8 82.5kg
Ohp     3x8 55kg
Rdl      3x8 95kg
Missed a day last week. Things are definitely getting harder now, especially because I'm still attempting to cut.
Ohp is suffering, so attempting a few different things to see what works. Open to any suggestions. Dropping rows down a little this week.
21/08/2016
Squat   3x10 97.5kg
Bench  3x8 85kg
Row     3x8 80kg 1x12 1x8 60kg
Ohp     1x8 60kg 2x8 1x4 50kg
Rdl      3x8 97.5kg
Did something to my leg so no lower body till it heals.
24/08/2016
Squat
Bench  3x8 85kg
Row     3x8 40kg dbs cant do bb at the moment because of leg
Ohp     1x5 60kg 2x10
Rdl
  • 3 weeks later...
Been crook for a few weeks. Still not fully recovered.
Lowered the weights till I'm feeling better.
12/09/2016
Squat 3x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg That's all I had in me.
14/09/2016
Still not great, this took me ages to get through.
Squat 2x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg
Ohp 3x10 40kg
Rdl 3x8 80kg
Curls 3x8 15kg db's
20/09/2016
Pretty much the same as last time, feeling better now though will add weight next session.
Squat 3x10 80kg
Bench 3x8 67.5kg
Rows 3x8 67.5kg
Ohp 3x10 40kg
Rdl 3x8 80kg
Curls 3x10 15kg db's
Been squatting in work boots lately, the heel makes it much nicer on my knees. Going to look around for proper lifting shoes
03/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
Curls 4x10 15kg db's
03/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
I use adidas powerlifts for squats, love them
Had a look at the powerlifts, doesn't look like they do them in my size. Usually between a 13 and 14 US.
Heel height in a lot of those weightlifting shoes isn't much better than my work boots.
05/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
07/10/2016
Squat 3x10 90kg
Bench 3x8 77.5kg
Rows 3x8 77.5kg
Ohp 3x8 50kg
Rdl 3x8 90kg
19 hours ago, L33SH said:
Numbers are coming along!
Getting there, still trying to lose a bit of weight too. So that's probably making it a bit harder. Hovering at about 100kgs at the moment
19/10/2016
Squat 3x10 95kg
Bench 3x8 82.5kg
Rows 3x8 82.50kg
Ohp 3x8 55kg
Rdl 3x8 95kg
Curls 3x8 17.5kg db's
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
