Getting harder now and progress is slowing so added reps to some movements this week instead of weight.
24/10/2016
Squat 3x10 97.5kg
Bench 10 9 8 82.5kg
Rows 4x8 82.50kg
Ohp 3x8 1x4 55kg a couple push press in there too
Rdl 3x8 97.5kg
Curls 3x8 17.5kg
Edited by r31slpr
03/11/2016
Squat 3x10 100kg
Bench 3x8 85kg
Rows 3x8 85kg
Ohp 3x8 57.5kg Couple push press
Rdl 3x8 100kg
Curls 3x10 17.5kg
05/11/2016
Squat 3x10 100kg
Bench 3x8 85kg
Rows 3x8 85kg
Rdl 3x8 100kg
Curls 3x10 17.5kg
Feeling a bit off the last couple weeks, so just taking it easy for now.
14/11/2016
Squat 3x10 100kg
Ohp 3x8 57.5kg
Rows 3x8 85kg
16/11/2016
Split Squat 3x8 40kg
Bench 3x8 70kg
Rows 3x8 70kg
Ohp 3x8 50kg Couple push press
Rdl 3x8 90kg
Curls 3x8 15kg
  • 2 months later...
Still going at this, dropped off a little over christmas and new year.
Lowered weights on a few things, form was getting sloppy. Reps are a lot slower and more controlled now.
This week mostly looked like this.
16,18,20/01/2017
Squat 3x10 105kg
Bench 3x8 80kg
Rows 3x8 70kg
Ohp 3x8 50kg
Rdl 3x8 105kg
Curls 3x10 17.5kg
This weeks was pretty much all the same. Elbow is feeling a little better, shoulder is mostly ok. Have moved to 5x5 for ohp because i was getting too much of a pump with the higher reps and my shoulder would start sticking in the last couple reps.
30/01/2017, 01/02/2017, 03/02/2017
Squat 3x10 110kg
Bench 3x8 85kg
Rows 3x8 75kg
Ohp 5x5 55kg
Rdl 3x8 110kg
Curls 3x12 15kg
