Hi All,
Part of the first wave of v35 owners in Australia.
Abolsutely love the car, have owned it for about 5 years now....however it is now starting to fall apart
Anyway was driving on the weekend and noticed smoke coming out of my engine! Long story short I took it to the local mechanic the next day, who informed me that I have a cracked radiator that needs replacing. They quoted me $790 for a koyo radiator, installation and coolant.
Am I being a tad overcharged here?
I came across the same radiator on ebay (local supplier) for $289:
http://www.ebay.com.au/itm/RADIATOR-NISSAN-SKYLINE-V35-AUTO-MANUAL-2001-2007-KOYO-BRAND-NEW-/220872242160
I was thinking of buying this and paying for installation, so much question is what is a reasonable price to pay for installation (labour)?
Thanks in advance
Cheers,
Danny
I bought the exact same one from Ebay a few months ago, thought I could save a few bucks and just pay for installation. Ended up not being a straight fit as the mounting points for the fan were completely different and required modification. In the end I returned it got a refund and mechanic found one in NZ that was a direct fit and OEM as well. Ended up costing around $700 all up too. Mine was a series 2 sedan though and thats why it didn't fit apparently. If yours is a coupe it should be OK, but still I wouldn't guarantee it.
350Z has a different radiator cap position. I bought a cheap china one from ebay for a coupe, and of course it's not a direct fit. and mack around with it for 4-5hrs before it fitted in. Of course I bought a 2 core radiator which is double the thickness of the OEM. If you have someone with golden hands, yes why not, if not. forget it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
