hey guys i bought some 18 inch rims for my series 2 r33 gtst...
hey are 9 inch in width
i was thinking about putting 18/40/255 on the rear and
18/40/245 on the front
will they fit on the front and rear or will i have issues rubbing when turning or on the rear rubbing ?
what does everyone recommend? not really keen on rolling the guards or stretching tyres
Cheers dean
https://www.sau.com.au/forums/topic/430246-please-help-asap-tyre-sizes/
Are they 9 inch wide all round? You could go 245 or 255 all round or mixed as you mentioned.
I think they will fit your guards fine. But that also depends on how low your car is and how much camber you are running?
But the more common profile for a 255 is 35 i think...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
