Sau Nsw Official Half Way Robertson Meet Up 15/9/13
Ah that sucks. Well I just finished my ten day stint and have the rest of the week off :P
Not that that makes you feel any better :(
Pretty keen for this :D
Shell signed blood so she coming.
Bad luck Chris ! I would rather next week off ! Because GTA IS COMING !
Eh.. Only games I play these days are racing games/simulators. Have built myself a pretty epic setup/cockpit :P
BF4? :D!
Haha still unsure.... I was a massive fan on bf2 10 years ago, over 1500 hours played back in the day lol. Bought bf3 and played it for about 2 months then was over it. I have a feeling bf4 will be a repeat of bf3 so I'm a little hesitant :(
Whereas I get a solid 4 hours a week out of Live for Speed, and don't get bored with that :D
Edited by dontyellpl0x
EA admitted to breaking BF3 - BF3 SUCKED ! however, they've realised their faults and will be fixing everything in BF4. By a start - they brought back commander
BF3 was amazing. The early maps where nothing special but the actual game was the best FPS released to date. The newer expansions are amazing.
New generation BF player? Becuase BF3 was probably the worse Battlefield installment. The graphics are amazing and to date, the best still. But the gameplay, competitive mode (There is no competitve mode - so you can't play BF3 competitively) and no commander, wayyy to many OP things example Anti-air and Jets do like 50% more damage to Helicopters - mind you Helicopters are a still target yet can be shot down in a second). there were MANY of things broken with BF3. Yes it was a good game from BF2 - but they quickly killed the game. Also, BF3 is dead - there are a total of like 10+ servers active during peak times.
I wouldn't complain anything is OP in BF3 tbh. Everything can be countered. ive got full platinum stars for both jets and choppers and i can get in one and make it last the entire game. Honestly the only "BROKEN" thing was metro with nades and rockets. Brilliant game.
Bf4 will be amazing. Not quite as good as GTA 5.
BF3 is dead and has been dead for quite awhile. I am a HUGE Battlefield fan and have been playing since game 1. EA have already admitted to its mistakes (Hence BF3 sucking) but they've promised to deliver in BF4 to which I think will happen.
Anyways, got that phonecall yet?
Edited by RosieR34
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
