So this morning I went to drive to work and my car just gave up. I unplug the igniter and the air flow meter when ever I go away for a weekend.
So I plugged them back in and then started the car. It idled for a little bit and as soon as I put it in gear and went to take off it stalled.
Now it won't even turn over.
Any ideas?
I checked both the igniter and the airflow meter plugs. It's my daily so I'm pretty screwed without it
https://www.sau.com.au/forums/topic/430484-car-wont-start/
Left your lights on? :P
I had a bit of a scare this morning. My electric key wouldn't unlock the door so I had to do it the old fashion way which released the alarm. Had no idea how to turn it off without the key working but then it just worked :D Small scares.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975765
Could still be a flat battery braaaaaaa. If it literally doesn't turn over at all, then either your starter motor is f**ked, the battery is dead, or a fuse/solenoid has shit itself somewhere. It's almost certainly nothing to do with the ignitor or AFM, unless it DOES turn over but just doesn't fire.
When you put the key in the ignition and turn it to start the car, describe EXACTLY EVERYTHING that happens - does it make a rattle/clicking sound? Does the engine turn over but not fire? Does it prime the fuel system?
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975779
No good man. Let's hope it's nothig major ! Summon Rob # He always seems to give great guidance / food for thought.
edit: I also had this similar issue couple of weeks ago. NRMA came out for 30 seconds to plug my alarm plug back on the battery hahaha I felt like an idiot.
Edited by RosieR34
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975780
Nah it has power you can hear it trying to turn over but it just doesn't grab. Lights 100% weren't on.
are you saying you can hear the starter spinning but not turning over the motor?
if this is the case turn it off then flick it straigh back on. sometimes will cause the pinion to push out as and grab the flywheel
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975822
Okay so when I turn the key I can hear it making the normal starting rev noise trying to start the engine.
But it just doesn't grab and start up. I have had a flat battery before and noticed it just makes a slight noise when that happens.
This is different. It's very similar to if you ran your car to empty and then tried to start it.
I do have a full tank of fuel though
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975846
if you're getting a clicking noise, kinda hollow, then your starter is gone (happened to my mate) if all electronics work fine then your battery is also fine...next up would be spark plugs? no reason for them to randomly die but who knows, could happen? maybe put up a sound clip of you trying to start it? if you said it sounds like trying to start a car on empty tank then yeah, might be sparkies cos that's what mine sounded like when i needed to change them too.
though one more thing - check the loom connections to the battery, all terminals are secure and not wiggling - then grab the looms and give them a wiggle, a few times, try and start the car, and wiggle again. might be a loose connection somewhere.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975927
Stop trying to start it and take it to a shop. You will risk detonation if it starts to flood the engine.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975933
Still didn't make it very clear lol....
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975992
Hahaha I was in a huge rush this morning so my mind was all over the place. It's kind of hard to describe a noise. Ill check the plugs again when I get home and also pull out the spark plugs and check them.
I can hear the fuel pump prime and then stop. But I'll pull a fuel line off and check that as well.
Anything else I should be checking as well?
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976007
i don't mean to sound like a dickhead (especially towards such a little sweetie as yourself, Dan), but you're still failing to answer the damned question lol :P
The engine "turning over" has nothing to do with it firing up - when you turn the key to the start position, does the starter motor turn the crankshaft successfully? I repeat - this has nothing to do with the engine firing, simply whether or not the starter is doing its job. If the battery is flat or if the starter motor has failed, the answer you'll be giving me here is "no".
When the key is turned to the final stage in the ignition (where it is supposed to start the engine), a few things should be happening - power is given to a small solenoid on the starter motor which causes the pinion gear on the starter motor's shaft to move out and engage with the flywheel. It then also gives power to the starter motor itself, causing it to turn the flywheel. If your battery has sufficient charge, these functions will still go ahead - the engine will "turn over".
Should the engine fail to fire as it should (and subsequently begin to run), the issue at hand will lie somewhere in the ignition system or fuel system (I'm not sure what will happen if the AFM is unplugged - will it not fire at all or run in some sort of limp mode?). Given you unplugged the AFM and ignitor, this is most likely where the fault lies - potential bad connection in the plugs (possibly from moisture as you suggested), or potential failure of one of these parts (possibly just bad luck when you plugged them back in).
While there are many many many things that can stop an engine from starting correctly, you should always start the investigation with things that have recently been fiddled with, especially if the car was running fine before you fiddled with them ;)
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976035
He means it wont fire.
So, basics guys, its spark or fuel.
you mean fluid lock? bust the head off?
Haha no pre-det. You would burn out your starter motor/flat battery before nearing hydrolock.
Dan by some electrical cleaner clean ignitor/afm my as well clean tb and cas sensor at the same time will get rid of moisture Charge the battery up give her another crack.
If its still no go it has to be spark or timing since you can here the pump prime.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976104
Hey Troy,
So I don't know the difference in the noise between those two steps in the start up you are talking about. Ill have to wait until I get home this afternoon. Might try get a video of it and send it to you.
I'll post up here this afternoon around 6:30 when I get home and start getting my hands dirty. Hopefully I can sort it out before work tomorrow
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976126
As per our sexting just now, you finally answered my question :P
Check AFM and ignitor plugs first - Do what Pat suggested and get some electrical contact cleaner to spray on the plugs and clean them out. Hopefully it's just moisture.
If that doesn't fix anything, check fuses. If the fuses look fine, then consider that by some unlucky chance either your AFM or ignitor shat itself at some stage through this adventure lol
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976187
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
