  • Replies 42
Have you checked the chassis number with Nissan to vertify that its in its original colour? That blue doesnt look standard to me and why the hell would you paint R34 GTR wheels white?
If it checks out then there is no reason not to buy if you are satisfied in your purchase.
Roy, Not a v-spec .. but it still has brembo's - lets hope the sale goes through :(
Blitz: good spotting.. it is a lighter than usual blue colour (I think!)
Though I am told by the dealer its 'Nismo Blue' - the car has white nismo gauges + dials, nismo pedals, plus a small, legit looking nismo badge on the opposite side to the GTR badge. The dealer told me he wasnt sure if it came out of the factory as a 'nismo' or if it was just a basic cosmetic mod the original owner did.
Has anyone heard of a nismo spec r34 gtr?
Also, the interior trim looks exactly the same as the interior in a GTR v-spec.. I dont remember the standard trim but is a standard GTR interior seats/trim any different?
Basically all the knowledge I really have of the vehicle is that it arrived in Australia with close to no kilometres in 1999 and has been driven and babied here ever since, and has done about 50,000kms since then on the digital odometer.
For the record, the car drives absolutely perfectly, its in as new condition and is a bargain I couldn't go past.
How much was this " bargain for " ? :wassup:
I am pretty sure i have seen this one years ago - the white 6 spokes ring a bell - I sat in it back in 2000. Was it complied by skyline imports? If it was it would have been probably one of the first 34 GTR's to be complied in Australia....
My bet is that it's been in a huge accident...
Something about the car just doesn't sit right. From the paint, to the wheels, to the dealer spinning stories about a "Nismo" model to explain the different blue colour... Just seems verrrrrrrrry dodgy.
Give us the engine number and chassis number and I'll try and get John @ UAS to look up the details of the car for you.
Pentae - What was the go with this car in the end? Did you purchase or was there issues?
Yeah I got it checked out, it was fine. - it had some previous panel damage on the left side of the car that had been repaired professionally and was unnoticeable without looking under the car.
The only thing wrong with the car was it was resprayed in a non original colour.
Did you get the RACQ report on this car because i rang them up last week about it and they told me it had been checked out by RACQ and every thing was fine they could not fault it ,and i specifically ask them about any damage or if it has been resprayed and they told me no it was nismo blue and it was some rare colour,
never heard of it on an R34 GTR also so noticed the GTR and nissan badges on the boot are in the wrong spot the GTR badge is about 20mm to low and the nissan badge is about 20mm to high this is why i thought it had been in a accident that and the nismo blue but they still insisted it was normal.
They also advertised this car in another car site as a V-spec for $65,000 with different number plates a bit suss.
No I didnt get an RACQ report on the car, I took it to one of the most reputable workshops in brisbane for imports and gtrs. :)
The car has definately had a respray from white; its not nismo blue.
And yes it was complianced through skyline imports.. my mechanic knew the guy who imported in about 4 of them and sprayed them all in this sky blue colour.
The vspec your talking about could be a different car..
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
